Help me diagnoss a problem - Road Glide Forums
post #1 of 6 (permalink) Old 11-07-2014, 03:26 PM Thread Starter
RGCJAX's Avatar
Just recently completed the following build:
Stage A/C
Boysen X wing
V&H Power Duals
V&H HO Muffs
GMR Genisis 577 cams
S&S Lifters
Zippers chain tenioners
Axtell oil Bypass kit
Problem I'm having is that after bike is up to temp I have eitms kicking in can not figure out what is creating the heat issue, I have loaded a cpl of maps sent to me with the Harley Super Tuner and did some smart tunes but can not eliminate the heat issue, any ideas what we should look for?
2011 FLTRX 103 SE A/C, V&H Power Duals w/V&H HO Mufflers, Axtell oil bypass kit, Boysen X Wing, GMR Genesis 577 Cams
RGCJAX is offline
post #2 of 6 (permalink) Old 11-07-2014, 03:37 PM
FrankieB's Avatar
Stage A/C
Boysen X wing
V&H Power Duals
V&H HO Muffs
S&S Lifters
If you are positive the tune is good then the next place I would look is under the cam cover. See if the cams are off a tooth.
06 RK
11 RGU
FrankieB is offline
post #3 of 6 (permalink) Old 11-07-2014, 03:41 PM Thread Starter
RGCJAX's Avatar
Will give that a check, we were sure we had the cams lined up properly, but you never know, I had thought that if it was off the bike would hardly run
RGCJAX is offline
post #4 of 6 (permalink) Old 11-07-2014, 06:39 PM
FrankieB's Avatar
I have read on other sites of people running them wrong for weeks before they figued it out. It isn't hard to get them off by a tooth.
06 RK
11 RGU
FrankieB is offline
post #5 of 6 (permalink) Old 11-08-2014, 09:34 AM
Do you know what the engine temp is when the EITMS kicks in??? Is it kicking in like it should at or around 290 F degrees.
The EITMS can be turned off so you can just do that if it is working properly. If the EITMS is kicking in early when the bike is not hot then the sensor may be bad, the EITMS temp sensor is located in the rear of the front cylinder head and you will see it if you look behind the horn.
It would seem that if the cams timing or crankshaft to cam timing gears are off a tooth you would know right away because the bike will not run right.
post #6 of 6 (permalink) Old 11-08-2014, 10:57 AM
Durwood's Avatar
Stage A/C
Boysen X wing
V&H Power Duals
V&H HO Muffs
S&S Lifters
The bike needs to be tuned, the maps you are flashing are just starter maps, also smart tuning with narrow band sensors is less than desireable, compared to a professionally tuned bike using wide band sensors.
Find a competent dyno tuner and get it tuned.
This is where 90% of the guys that have problems after doing performance upgrades miss the boat, they spend the coins on all the right parts, then stab maps at them trying to avoid spending the money on a GOOD tune, which IMO needs to be on top of the list.
Daren
Don't forget the tune.
Durwood is offline
Christmas came today 4 me from me pipe3214 General Off-Topic Discussions 13 10-26-2015 09:46 PM
cost me $39.83 to tell me bike is ok jrbean1 Engine Related 26 09-26-2013 04:45 PM
This is needy of me, but please let me know your thoughts Gadgetech Aftermarket Accessories 20 12-28-2010 11:00 PM
Uncommon Problem-Need Help!! BDMastiff *General Road Glide Discussions/Pictures 28 10-25-2010 05:44 AM
Call me outta date , I call me cheep JacktheBagger Seating: seats, backrests 12 08-31-2010 06:39 AM
