Thought on a noise - Road Glide Forums
post #1 of 11 (permalink) Old 11-07-2014, 05:19 PM Thread Starter
93-331-29psi's Avatar
Thought on a noise
So when I got home today and was pulling bike into garage I noticed a disturbing knocking in the engine. Closest thing I can relate it to is a rod knock you'd hear in a SBC with a bad rod bearing.
Pretty sure I'm done riding for a while but wanted to get thoughts. I will go make and post a video for review.
93-331-29psi is offline
post #2 of 11 (permalink) Old 11-07-2014, 06:10 PM Thread Starter
Don't mind the image portion. I just tried to get the microphone close.
http://youtu.be/aZBaxqwWr-0
post #3 of 11 (permalink) Old 11-07-2014, 06:34 PM
FrankieB's Avatar
It is hard to hear in the video, but i will throw a couple thing out to check. If it is on the right side and sounds like two pieces of wood knocking it could be reversion coming out the throttle body. On the primary side i would have a look at the compensator and the torque of the nut/bolt.
06 RK
11 RGU
FrankieB is offline
post #4 of 11 (permalink) Old 11-07-2014, 06:42 PM Thread Starter
It is on the right side and does sound like a wood on wood sound. I've never heard it before today. What do I do to resolve it??
post #5 of 11 (permalink) Old 11-07-2014, 07:36 PM
FrankieB's Avatar
If it is reversion you can hear it coming out of your throttle body. There isn't much you can do about unless you want to spend money on different cams and exhaust to test. A stock style air cleaner will quiet it down some. My 107" bike with and open a/c and the cams i run are very noisey also but i have gotten used to it.
06 RK
11 RGU
FrankieB is offline
post #6 of 11 (permalink) Old 11-07-2014, 11:34 PM
Any decel poppin?, Crisp moist night air change anything, like exhaust note, your bike sounds nice, not the stock cams
reds4 is offline
post #7 of 11 (permalink) Old 11-08-2014, 07:50 AM Thread Starter
No decel pop at all and it seems to still run decent. I went out this morning and started it up and I have no knock but it is still noisy (chattery).
I spoke with Frank at Drago's for a good hour last night to discuss rebuild options and based on our conversation I'm pretty certain I have a bad lifter as the bike has gotten progressively louder over the past few months and the knock only appears when it's up to temp.
I'm going to pull the lifters today and hopefully find them to be the culprit. It'll buy mea few more months before I "have" to do a rebuild but when that time comes Frank has my business.
post #8 of 11 (permalink) Old 11-14-2014, 07:26 PM Thread Starter
Well I threw some Lucas oil treatment in with the engine oil and I thought for a minute I was riding a gold wing. The engine purrs quiet which eliminates the compensation sprocket as the culprit. So I'm convinced the lifters are the problem. Will be contacting Drago's tomorrow for some new ones. Hope to be up and operating by mid week.
post #9 of 11 (permalink) Old 11-14-2014, 07:42 PM
I use a quart of Lucas in every oil change. Many bikes , many engine designs, many miles.
Big_gary is online now
post #10 of 11 (permalink) Old 11-16-2014, 01:17 AM
vontoughguy's Avatar
It sounds just like the sound that have came From my motor 3 times.
The first time HD changed the cams and lifters, then he second time they found a bad flywheel the next time after 10,000 miles the noise came again and they found the flywheel had gone bad again. Read the thread back in the shop.
Is the ticking more noticeable at 20 mph?
vontoughguy is offline
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
Thought you guy's would.... xusnatc *General Road Glide Discussions/Pictures 11 06-05-2011 06:25 PM
lowering thought Graybone32 *General Road Glide Discussions/Pictures 9 06-03-2011 05:50 AM
just thought i'd say hello BCRG New Members Welcome Area 11 05-27-2011 10:04 PM
Seat thought Frodoe *General Road Glide Discussions/Pictures 4 03-16-2011 08:02 PM
