To stroke, or not to stroke a 88"? - Road Glide Forums
post #1 of 15 (permalink) Old 11-10-2014, 08:58 PM Thread Starter
1drwfan's Avatar
I have a 06 RG with an 88" that I had some motor work done to about 2 years ago...added big bore kit to make it a 97", fuel management, zippers air, performance exhaust, gear drive cams (Andrews 50), dynos at 96HP and nice curve at 96TQ but most of the power comes on around 2,800rpm. Fun to ride now but thinking i want more lower end torque.
Am debating another upgrade to the motor as I prefer the styling of the older RG versus 2015's. Stopped at my motor builders to discuss port/polish heads, roller rockers, and changing to Andrews 57 cams to get some lower end torque without loosing upper end. He states that would help some but is recommending to stroke the motor to a 106" instead and stay with the 50 cams. He says HP would only raise to around 100-105 but torque would increase to 110-115 and give a lot more on the lower end for day to day riding. Thoughts?
2006 FLTRI Yellow Pearl with 97" S&S Big Bore kit with Andrews 50G cams
S&S Power Tune Headers with Screaming Eagle mufflers and powercommander fuel management
Zippers A/C upgrqade with K&N filter, Dyno Tuned at 96 horsepower & 96 ft pds torque
1drwfan is offline
post #2 of 15 (permalink) Old 11-10-2014, 11:02 PM
There's no substitute for cubic inches.
If you decide to increase the stroke, the S&S Crank is the way to go...
HeatWave is offline
post #3 of 15 (permalink) Old 11-11-2014, 06:32 AM
With an S&S 4 3/8" crank and a set of S&S 4 1/8" cylinders you could be at 117".
You probably won't want for more.
We build a lot of these.
Scott
Hillsidecycle.com is offline
post #4 of 15 (permalink) Old 11-11-2014, 08:24 AM
mocotom's Avatar
As mentioned there is no substitute for cubic in, but with the right cam your 97" will make riding your Harley fun again. Over caming a street driven Harley defeats the purpose of the v-twins design and is the most reoccurring complaint from owners. Big cams need big cubes and a lot more of your money.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 15 (permalink) Old 11-11-2014, 08:25 AM
124shark's Avatar
Being that you have liked the current build a simple 103,106, 107 style kit will build great low end power. Not be over costly to build ( 117 cylinder kit is 900 dollars approx by itself on top of the crank) A 106 with a ES 570 cam mild head work simple bolt on throttle body will make 115/115 + on pump gas at a whopping 10.2 compression. A 117 is a great build but do not forget the extras you need .. Good luck..
2012 FLTRX 124 S&S
124shark is offline
post #6 of 15 (permalink) Old 11-11-2014, 08:33 AM
Durwood's Avatar
You would be surprised what you could get out of your 97 by having the heads massaged by a pro, like Hillside, I have seen these builds set at 10-1 with S&S 570's go 100/110. Pipe selection is paramount.
Sure, adding more cubes will add more power, and if money isn't an issue, then by all means rock on.
Don't forget the tune.
Durwood is offline
post #7 of 15 (permalink) Old 11-11-2014, 12:48 PM
Redbeard77's Avatar
You've got tons of options depending on your budget. Be realistic about ALL the costs associated with tearing into your motor, and maybe a new crate motor makes more sense. And depending on your actual riding style, you might be happy with a heads/cam change.
Happiness is a warm motorcycle.
Redbeard77 is offline
post #8 of 15 (permalink) Old 11-12-2014, 06:45 AM
Yep.
The very first time we ever used that .570 cam was when Jim Kennedy tuned that 98"/ 10.0 cr/our heads/Rhinehart duals, about 3 years ago. Client was from Tennesee.
107/114, std, if I remember correctly?
Just installed that cam last week in a 2009 RG CVO 110", set at 10.0 cr, with a 30T trans sprocket......snappy combo.
RG combo this week was a 2015 S/E 110" Fatcat/58mm/Stage I 110" headwork/Wood 777's at 10.5 cr...........REAL snappy.
Scott
post #9 of 15 (permalink) Old 11-12-2014, 10:18 AM
Olskoo's Avatar
Check out my post and specs. on my 107 build . I couldn't be happier.
Olskoo is offline
post #10 of 15 (permalink) Old 11-12-2014, 11:15 AM
Faced with this same decision, I opted for a 2013 Ultra with a 103 motor. World of difference. Torque out the wazoo. Able to climb trees now with no problem. (slight exaggeration for effect)
August is offline
88" upgrade to 95/97" and geardrive build recs and outcomes silverglide Engine Related 12 05-24-2016 09:34 AM
The new Indian engine - 111 Thunder Stroke CHAINSAW General Off-Topic Discussions 50 03-12-2013 10:31 PM
88" to 96" mrbill Engine Related 2 03-19-2011 04:45 PM
