s&s 124 - Road Glide Forums
post #1 of 9 (permalink) Old 11-15-2014, 10:01 PM Thread Starter
jaysrgu's Avatar
s&s 124
ordered my 124 lc today will have in 2 weeks,for others that have put this into there road glides what throttle body and injectors did u use? i have a 54mm throttle body and stock injectors to start out with,will be running vh power dual pipes and kuryakn crusher mufflers,i have a tts master tune so will need to get this set up as well,will be a good year next spring
jaysrgu is offline
post #2 of 9 (permalink) Old 11-15-2014, 11:15 PM
idahointrudr's Avatar
Did you sell your old motor?
Are you doing the change for the power?
Reason i ask I am considering the upgrade after I put some more miles on my 103
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #3 of 9 (permalink) Old 11-16-2014, 09:45 AM Thread Starter
jaysrgu's Avatar
no i will just pull out old motor,prob put it up for sale in the near future,currently have a 103 punched out to a 105,kuraykn 24d cam,larger valves,bee hive springs,heads ported and decked,but yeah i want more power and want to do it reliably,s&s makes some damn good parts compared to the moco
jaysrgu is offline
post #4 of 9 (permalink) Old 11-16-2014, 10:14 AM
Deadstroke's Avatar
HPI 58 seems to be the sweet spot for that motor, I didn't take my own advise and went with a 66tb and I don't care for it. Now since u aren't doing a 2 in 1 I prob would say save ur money and roll with what u have now. Let me know how much u want for the old motor I may me be interested.
2014 - Street Glide - 107 Motor
2015 - Road Glide - Stage 3 Blower Motor & Aerocharger
Deadstroke is offline
post #5 of 9 (permalink) Old 11-16-2014, 01:41 PM
The 124 will like a polished SE 58mm or HPI 58 with 5.3 injectors.
V&H PowerDuals are fine, as are the Kury mufflers.
S&S will supply a spot on map for the PowerVision, the TTS will require a dyno.
HeatWave is offline
post #6 of 9 (permalink) Old 11-16-2014, 07:05 PM
FLTR2008Trike's Avatar
If you go HPI, you will want the 58/58 TB with 1.80 runners for your S&S 124".
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #7 of 9 (permalink) Old 11-16-2014, 10:20 PM
torqu's Avatar
Jay, S&S has some new throttle bodies out. I believe they are called "Throttle Hogs". I would call the S&S tech to see which one they would recommend.
torqu is offline
post #8 of 9 (permalink) Old 11-17-2014, 06:34 AM
We'd use either a 58, or 66mm S&S Throttle Hog.
Scott
Hillsidecycle.com is offline
post #9 of 9 (permalink) Old 11-18-2014, 10:18 AM Thread Starter
jaysrgu's Avatar
when using the 585 cams in the lc motor does one need oversized injectors,again wondering what others have found works well
jaysrgu is offline
124 s&s / 120r to 124 Vinny Engine Related 80 05-18-2015 12:58 AM
Dragos 124 engine/S&S 124 JKRSDETROIT Engine Related 41 03-14-2015 11:50 AM
163HP 144TQ on 124 With S&S B2 heads Dragula 2.55 baffle DragoBikeWorks Dyno Results 0 09-10-2013 01:13 PM
S&S 124 ci Evo motor natural finish Toecutter Sold 1 05-11-2013 03:02 AM
