Oil cooler fans - Road Glide Forums
post #1 of 9 (permalink) Old 11-17-2014, 08:38 PM Thread Starter
Oil cooler fans
Ok guys. I'm interested in these oil cooler fans that just plug and play into your acc switch and are virtually unnoticeable behind the oil cooler. I've looked into Big Sky Fans, and CDA VTwin.
I was curious if anyone has installed these, and what you think. They aren't expensive, I just was wondering if they work worth a shit.
Thanks,
Loner
Loner is offline
post #2 of 9 (permalink) Old 11-17-2014, 09:15 PM
Check with Q-Hoq, I'm sure he has that set up.
post #3 of 9 (permalink) Old 11-17-2014, 09:15 PM
Q-Hog's Avatar
I have the Big Sky Fan. It works great for me and easy to instal. I have mine on a manual switch.
Q-Hog is offline
post #4 of 9 (permalink) Old 11-18-2014, 07:18 PM Thread Starter
Thanks Q-Hog. Big Sky it is....
Loner is offline
post #5 of 9 (permalink) Old 11-18-2014, 08:10 PM
jack6hd's Avatar
Big Sky fans on my RG for 2 years now. Easy install and no problems.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #6 of 9 (permalink) Old 11-19-2014, 03:52 PM
oil cooler
I have one of UltraCools first. with the cover (chin spoiler)
http://www.ultracoolfl.com/
2010 FLTRX,103 Stage 2,FullSac 2-1-2, black ceramic CB/Intercom, Power Vision
websterdan is offline
post #7 of 9 (permalink) Old 11-20-2014, 01:19 PM
'Have the Big Sky Fans on the Aux switch.
The BSF have dropped and stabilized the oil temps.
Highly recommend.
HeatWave is offline
post #8 of 9 (permalink) Old 11-27-2014, 07:20 AM
Hammer Down's Avatar
I run the Ultra Cool as well. So far I have been very happy with it. Comes on automatically at 260 degree oil temp and has a green LED light to let you know it is on.
2010 RG Custom, S&S 106, Dan Vance Racing Heads, Cycle Rama 575 cams and lifters, SE Adj pushrods, Dan Vance 54mm Throttle Body, Dragos 2:1 Exhaust, DynoJet Power Vision with tunes from Fuel Moto customized by me.
Hammer Down is offline
post #9 of 9 (permalink) Old 12-12-2014, 09:44 PM
Thermodyne's Avatar
I run the fans from Big Sky. They work OK. I had an instal issue with needing to space the cooler forward about 1/4 inch.
If you just want to keep the oil temps down, then they'll do the job. If you need to keep the motor temps down, then you'll need to look at some head/jug fans. Wars Parts Works has a set that work well.
I don't even watch my oil temps anymore, I just watch the head temps.
Thermodyne is offline
Oil Bud Oil Cooler easybiker Engine Related 10 07-22-2015 02:34 PM
Oil Bud Oil Cooler install 2013 RG ultra Big_Mo Aftermarket Accessories 0 08-09-2014 10:32 AM
Removing oil filter with oil cooler 02heritage *General Road Glide Discussions/Pictures 17 05-12-2014 12:10 AM
Oil Cooler/Fans!!! Q-Hog Engine Related 16 09-12-2013 09:15 PM
Jagg Oil Cooler turned to Oil Drooler! OldNerdGuy *General Road Glide Discussions/Pictures 6 07-22-2013 12:04 PM
