2007 96 inch - Road Glide Forums
post #1 of 8 (permalink) Old 11-20-2014, 08:16 PM Thread Starter
sj01fltri's Avatar
2007 96 inch
A friend has a 07 96 inch street glide,he is wanting to put cams in it,so my question is how big of lift can he go with stock heads without doing valve springs,i know on the later 103's 575 is a safe bet but can go up to 600 lift.Thanks.
sj01fltri is offline
post #2 of 8 (permalink) Old 11-20-2014, 08:54 PM
The search button is your friend. HD & aftermarket cam mfg can supply you with all the info you need. Good luck
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 8 (permalink) Old 11-21-2014, 06:04 AM
Same spring pack in that 96" head, but that said, a great cam for that is an Andrews 48.
Any tuner worth his salt can put him at 90 hp and 100 ft/lbs once tuned.
Stocking item here.
Scott
Hillsidecycle.com is offline
post #4 of 8 (permalink) Old 11-21-2014, 10:38 AM
They say you can go up to .600 lift on the stock valve springs but keep in mind that that much lift is hard on the stock springs.
Also any lift over .550 is pretty much a waste and there would be no real benefit from that much lift until you get into a big build engine.
Most good cams that provide great performance are around .555 which is easier on the entire valve train.
The cams valve timing and duration affect the way the bikes engine performs more than the cams lift.
post #5 of 8 (permalink) Old 11-21-2014, 10:44 AM
bucketlisthd's Avatar
I have an Andrews 48 and a Fuel Moto tune in my 96". Runs great.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #6 of 8 (permalink) Old 11-21-2014, 12:20 PM
PBSTN's Avatar
I am running Andrews 48's with a Drago's map in my 96". Runs perfect.
2001 FLHR-Traded. 2010 FLTRX-Sold.
2010 FLHR
2003 FLHRSEI2
PBSTN is offline
post #7 of 8 (permalink) Old 11-21-2014, 04:20 PM Thread Starter
sj01fltri's Avatar
Thats the info i was looking for thanks Scott.
post #8 of 8 (permalink) Old 11-24-2014, 06:42 AM
Your welcome, and I'll add we have all in house to allow a trouble-free install.
Scott
TW6 cam in 96 inch duane5157 Dyno Results 8 04-10-2015 07:04 AM
2007 96" jugs & Pistons with only 700 miles for sale sloride Parts for Sale 2 07-23-2014 09:54 PM
WTB 2007 FL touring swingarm setup and 2007 streetglide wheel my98glide Wanted! (Buy or Trade) 0 04-03-2013 09:08 PM
Little help here on wheels, 17 inch vs 18 inch rear... BigDeez Wheels and Tires 1 06-22-2012 08:00 PM
