CVO Cams - Road Glide Forums
post #1 of 12 (permalink) Old 11-26-2014, 01:34 PM Thread Starter
Darreldanger's Avatar
CVO Cams
Hey guys, what cams is HD putting in the CVO's nowdays?
Darreldanger is offline
post #2 of 12 (permalink) Old 11-26-2014, 05:28 PM
I still think it's the SE255.
2016 CVO Road Glide
SMSgt B is offline
post #3 of 12 (permalink) Old 11-26-2014, 07:30 PM
Yes 255
DragoBikeWorks is offline
post #4 of 12 (permalink) Old 12-02-2014, 06:35 AM
Why do you ask?
Scott
Hillsidecycle.com is offline
post #5 of 12 (permalink) Old 12-02-2014, 09:45 PM Thread Starter
Originally Posted by Hillsidecycle.com View Post
Why do you ask?
Scott
Because I am putting cams in my 12 RGC and am concerned about lift and longevity. If HD is installing .555 lift cams (SE 255) then I would think that much lift would be safe for the long haul. People are quick to say this cam or that cam makes this much HP, but will it live. I don't want to be checking or changing my lifters every year. I would rather just leave a little lift on the table... Having said all that, I will probably go with the andrews 57H and hope it's not to much.
post #6 of 12 (permalink) Old 12-02-2014, 11:51 PM
Desertwndrr's Avatar
Andrews 57 is a great cam. I used TMan 555TQ cams and they made awesome power. Andrews 48's or Woods 222's are also great choices for a stock 103. I have the CVO255 cams in my wife's softail, but had to work the timing map a little bit. I think that they can work well in a 103 bagger if the tune is right, but they are a little better suited to a 96" with slightly lower compression.
Desertwndrr is offline
post #7 of 12 (permalink) Old 12-03-2014, 06:40 AM
It's not the lift that raises hell with the lifter, but rather spring pressure and cam lobe profile.
The HD "C" lifters in that 2012 bike are manufactured in Mexico, and have been known to have issues.
If wanting to sleep soundly, then install a set of S&S Premium lifters at the point on the cam install.
We've used that 57 quite a few times now, and have found that 9.8-10.0 cr is where it wants it.
Scott
post #8 of 12 (permalink) Old 12-03-2014, 12:21 PM Thread Starter
Scott
Which pushrod?
post #9 of 12 (permalink) Old 12-03-2014, 12:40 PM
RichieRich's Avatar
Is there a reason why the standard S&S lifter won't work? The premiums are twice the cost. What justifies the added expense?
2013 BBP FLTRX
RichieRich is offline
post #10 of 12 (permalink) Old 12-03-2014, 10:17 PM
Not 100%, but I believe that I've read that the standard S&S lifters aren't entirely built in the USA. THe premiums are. I believe that they are built to tighter tolerances as well.
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
Se cvo-255 cams 150 shipped bpt-bagger Parts for Sale 1 11-20-2013 07:09 PM
Cams For a CVO Silverbullet Engine Related 22 10-21-2013 07:34 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
Cvo screaming eagle 255 cams with 0.9 miles on them akawolf Sold 20 12-24-2012 10:56 AM
