551 vs 585 cams - Road Glide Forums
post #1 of 5 (permalink) Old 08-21-2010, 04:12 PM Thread Starter
551 vs 585 cams
Hi new to this site.My question is this,I'm installing a 106 S&S big bore kit on my 2007 road glide.It has vance and hines 2 into one exhust.Kururakyn
Hi five air cleaner , Harley Davidson Hi flow CNC'd heads that just were released are also going to be installed.The 551 cam is for torque in the low rpm range.Should I use the 585 cam which is more for midrange.I'm wondering if the lift on the 551 is not high enough to take advantage of the ability to flow alot more air.Or would the 551 low end torque cam still be suitable.Compression on the 106 kit is just over 10 -1 Any info would be appreciated.Any dyno charts on this site.Thanks
watty is offline
post #2 of 5 (permalink) Old 08-21-2010, 05:19 PM
Admin
BillyBob's Avatar
Might want to post this in Gary's corner. Welcome
BillyBob is offline
post #3 of 5 (permalink) Old 08-21-2010, 05:45 PM
JacktheBagger's Avatar
Dont know if you looked at the S&S site but here's the page ..
If you're gonna keep it wound up mebbe the 585 otherwise the 551 which is my next big expense .. 551 is better suited for our bikes ..
http://www.sscycle.com/feature/featureview.php?s_id=10
2011 Ultra
JacktheBagger is offline
post #4 of 5 (permalink) Old 08-21-2010, 06:03 PM
BDMastiff's Avatar
I don't know weather or not this will be helpful. I have a Big Dog with a S&S 117. A lot of the Big Dog guys put the 551's in their motors. Truthfully, I'm not knowledgeable enough about cams to give a solid answer.
1996 Fatboy
BDMastiff is offline
post #5 of 5 (permalink) Old 11-16-2010, 02:29 PM
I run the 585's in my 107, no head work, pro pipe Hi-output Kury filter
haven't dyno'd it yet, bike runs great, it's a little slow on the bottom but
rockets when you hit around 3K.
I built it (oh niner) RG for better mid to upper power for highway riding, in 5th I can open it up and it pulls all the way to the rev limiter.
Now normally for a big bike you want all TQ and I would advise you to go 551 for low end power, and 583 for all over (better low, good mid, and some High)
Hotroadking is offline
WTB S&S 551 Easy Start Cams swampking Wanted! (Buy or Trade) 0 10-23-2015 09:36 PM
S&S 551 cams ShitHouseRat Parts for Sale 8 09-27-2013 07:28 AM
S&S 551 cams ShitHouseRat Engine Related 9 07-24-2013 04:47 AM
S&S 551 gear driven cams Loner Intake and Exhaust 18 12-19-2012 06:37 AM
S&S EZ start 551 cams eyeman Engine Related 1 02-28-2011 04:06 PM
