2013 RG with ping at WOT - Road Glide Forums
post #1 of 14 (permalink) Old 10-18-2015, 02:23 PM Thread Starter
cookie114's Avatar
Purchased a 13 Road glide about a month ago from local HD. The bike had 6k miles on it and has been tuned at that HD with mastertune 2 and also has V&h power dual headers with v&h monster round mufflers. No other mods to the bike. My problem is that it has a noticeable ping (like a spring jumping around ) when I'm at WOT and above 4000rpms. Took to dealership and they rode it 10 miles after it was cooled off and said they can't duplicate ping. I believe they can't duplicate it because it only does it when at WOT and above 3800-4000 rpms and they probably aren't pushing it to that. What to do next?? Tuning issue?
cookie114 is offline
post #2 of 14 (permalink) Old 10-18-2015, 02:45 PM
Perlinal's Avatar
Re tune it with a real tuner (someone that really knows what they are doing who usually doesn't usually work at a HD dealer..) sooner rather than later. Not something you want to mess around with.
Perlinal is offline
post #3 of 14 (permalink) Old 10-18-2015, 03:54 PM
FDXGUY's Avatar
My 13 was the same way. A canned flash isn't going to fix it. Your bike is running to lean and the timing is off. As stated above, get a real tune on it or run a fully adjustable tuner/programmer.
FDXGUY is offline
post #4 of 14 (permalink) Old 10-18-2015, 04:49 PM Thread Starter
cookie114's Avatar
Fdxguy- that's what I'm thinking as well. HD tries to pretnd what I'm hearing is normal for the heavy touring bikes but it's bullsh*t. What about those vance&hines tuners with auto tune??
post #5 of 14 (permalink) Old 10-19-2015, 11:56 AM
A tuner with auto tune needs the 18mm closed loop O2 sensors and if you don't have them then the tuner isn't a true auto tune.
A tuner that has auto tune ONLY AUTO TUNES THE AFR it does NOT tune or adjust timing, the engine timing needs to be adjusted manually.
You problem is in the timing and it isn't in the AFR so a timing adjustment needs to be done to get the ping out.
As mentioned a good tune would be needed by a competent tuner tech.
post #6 of 14 (permalink) Old 10-19-2015, 04:35 PM
You already have the Mastertune, don't know where your located but if any where near Florida, Doc is a journeyman with it.
rg113 is offline
post #7 of 14 (permalink) Old 10-19-2015, 04:56 PM Thread Starter
cookie114's Avatar
I'm in Northeast GA and have not a clue of any reputable tuners around me. I'm sure there is some within driving distance but not sure of them
post #8 of 14 (permalink) Old 10-19-2015, 05:16 PM
pat123's Avatar
Call Bill at Woods Performance tuning. He is in Cartersville Ga and he's awesome. He tuned my 124 with TTS and it flat out runs perfect!
WOODS PERFORMANCE TUNING - Home
pat123 is offline
post #9 of 14 (permalink) Old 10-19-2015, 05:56 PM Thread Starter
cookie114's Avatar
Appreciate that. I'll be giving him a shout
post #10 of 14 (permalink) Old 10-19-2015, 09:51 PM
Road dawg's Avatar
+1 on that, woods is Top Notch! better than the stealer.
Road dawg is offline
Top speed wot ? railer60 *General Road Glide Discussions/Pictures 36 02-04-2018 08:14 PM
Best HP WOT A/F Darreldanger ECM/Fuel Management systems 0 10-21-2016 04:22 PM
Stutter at 70-90 MPH on WOT? HogPro *General Road Glide Discussions/Pictures 1 07-15-2015 05:39 PM
Running erractic, sputters on WOT etc HogPro *General Road Glide Discussions/Pictures 12 01-07-2015 08:25 PM
ping... Ping... PING philmartin *General Road Glide Discussions/Pictures 20 07-25-2011 10:10 PM
