Hard Starts - Road Glide Forums
 2Likes
post #1 of 15 (permalink) Old 11-02-2015, 07:05 PM Thread Starter
boneaho's Avatar
Hard Starts
I have an 09 roadglide it has a 96". All i have done since i owned it (engine wise) is pull the baffles out if the slip on rinharts. Anyway about every 10 starts I get a hard start. It turns over and is then followed by a grind. It's almost like the motor is at the perfect compression. It will eventually start. I also put in a new batt this spring.
boneaho is offline
post #2 of 15 (permalink) Old 11-02-2015, 07:50 PM
RGKen's Avatar
My 2010 did it and just recently my 2012 started doing it. Both times the problem was solved with a new compensator. Could be another cause but I believe a bad comp is the most common.
2018 FLTRXS
RGKen is offline
post #3 of 15 (permalink) Old 11-02-2015, 07:55 PM
Replace the compensator. You may need to rebuild the starter as well but your compensator is the major culprit. I had the exact same thing happen. Ever since the MoCo started putting the 96 in they've had nothing but problems with compensators. Some of the 103's have this problem too. I believe HD superceded the part numbers for the comps about 4 or 5 times since the 96"ers. As far as what to replace it with? Well that's a question for the ages. So far no one has been able to come up with a bullet proof design.
post #4 of 15 (permalink) Old 11-02-2015, 08:09 PM
Besides the ovious (compensator) , make sure your battery is strong and a good set of spark plugs will kick the engine over easier.
post #5 of 15 (permalink) Old 11-02-2015, 08:43 PM
Does it do it only only in gear (clutch in)?
Try neutral , esp when motor hot
"followed by a hard grind " or hard grind start??
reds4 is offline
post #6 of 15 (permalink) Old 11-03-2015, 09:23 AM
+1 on the compensator. There is a real good chance that the starter is just fine so don't R&R that. Replace the compensator first then see how the starter acts.
post #7 of 15 (permalink) Old 11-03-2015, 10:38 AM Thread Starter
boneaho's Avatar
ok...compensator it is. Help me out here, should i go back to hd and get one? Does anyone make a better aftermarket version? How had is it to change? Do i need any special tools? Also i have the extended warranty is it coverd under that?
boneaho is offline
post #8 of 15 (permalink) Old 11-03-2015, 11:06 AM
I experienced the start problem on my 2007 Road Glide. I had Manual Compression Releases put in and it totally solved the problem. Anytime I start the engine I first push the MCR's and it just starts. I have 71,000 with the OEM compensator and have no hard start problems. It's quite inexpensive to install the MCR valves and takes only a short time.
BART
BART1 is offline
post #9 of 15 (permalink) Old 11-03-2015, 11:22 AM
yes,yes,not hard,not really,yes
But, was told if it's not or if they can't see a way to claim (!), you pay for the lookie's
Haven't heard good or bad on HD near you
reds4 is offline
post #10 of 15 (permalink) Old 11-03-2015, 12:28 PM
Yes the compensator is covered under the Harley Extended warranty.
How hard is too hard? tlottman *General Road Glide Discussions/Pictures 11 08-28-2015 07:42 AM
01 Road Glide - Dies NO power then starts OnPhyre Troubleshooting for Road Glides 8 03-09-2012 10:45 PM
06 RG dies no spark- re -starts? jon06 Troubleshooting for Road Glides 11 01-08-2012 10:02 PM
Ride for fun in NJ 7/10 . All day ride starts at 10am mea4dxl Organize Rides Here 0 07-09-2011 07:50 PM
My cross country charity ride starts today! BACA POPEYE Road Trip Discussions/Stories/Pictures 16 06-22-2011 02:28 PM
