start - Road Glide Forums
  • 1 Post By 09Sharknose
post #1 of 8 (permalink) Old 11-08-2015, 03:12 PM Thread Starter
start
my bike has developed a starting problem that is intermittent.
After leaving the bike in the garage for a period time ( 2 days to a week), when I start it, it fires up just fine. Other times, it will turn over hard initially, almost like its not going to start. Sometimes I release the starter at this point and get a "puff: out of the breather and smell a little gas. When I try to start it right after that, it starts fine.
This situation does not seem to depend on temperature.
I tested the battery after leaving it overnight and it still registered in the acceptable rage. 12.6 volts.
could it be timing? compression release valve? Maybe batter?
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #2 of 8 (permalink) Old 11-08-2015, 03:42 PM
Sounds normal for FI, that's low batt range tho, probably does it more after sitting cold, give the FP time to whine
reds4 is offline
post #3 of 8 (permalink) Old 11-08-2015, 05:18 PM Thread Starter
Although I did not know it, my SE PRO super tuner can record the volts of my battery. Later today, I will hook it all up, and crank the engine with the spark plug wires removed to see if the cranking volts go below 9volts.
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #4 of 8 (permalink) Old 11-08-2015, 10:02 PM
idahointrudr's Avatar
Mine started doing that during my last ride three weeks ago. It was hot and had been riding all day.
I blamed it on bad fuel.
I got the ethanol free stuff at my favorite station and hasn't done it since.......though i have not ridden much. Just around town.
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #5 of 8 (permalink) Old 11-08-2015, 10:56 PM
bucketlisthd's Avatar
Might have been bad fuel, but doubt it was the ethanol. That's all we have around here. No choice.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #6 of 8 (permalink) Old 11-09-2015, 12:00 AM
09Sharknose's Avatar
Your compensator is going out. "Intermittent" will gradually become more and more often.
RGKen likes this.
09Sharknose is offline
post #7 of 8 (permalink) Old 11-09-2015, 09:08 AM
Smarty's Avatar
Be sure and not try and fire your bike with the plug wires removed. If you do, get an old set of plugs and hook the wires to them when you turn the motor over. You can cause significant damage to the ignition systems by doing this.
Smarty is offline
post #8 of 8 (permalink) Old 11-10-2015, 06:20 AM
mechanicalman's Avatar
Make sure the compression releases are enabled. I see that some of the canned maps are ACR disabled. Look in the tuning setup section.
2012 FLTRU, S&S tear drop AC, modified V&H Pro pipe, Andrews 57h Cam, S&S quicky push rods. Kensun 55 W HID headlights. Heat Demons grip heaters.
mechanicalman is offline
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 09:03 AM
Start-up Question OldSalt Road Glide Specific Discussions 17 01-19-2011 10:05 PM
Start Date NakedSnowman General Off-Topic Discussions 8 01-05-2011 07:03 PM
bike won't start briscoe *General Road Glide Discussions/Pictures 11 11-28-2010 11:25 AM
Bike will not start pte359 Troubleshooting for Road Glides 13 08-19-2010 04:55 PM
