Clutch spring - Road Glide Forums
post #1 of 15 (permalink) Old 11-09-2015, 12:56 AM Thread Starter
MightyWhitey's Avatar
Clutch spring
Is the 6 spring setup worth the extra coin vs upgrading to the heavy duty diaphragm spring?
MightyWhitey is offline
post #2 of 15 (permalink) Old 11-09-2015, 07:50 AM
FrankieB's Avatar
Depends on how much power you are putting down and at what RPM the clutch is slipping at.
06 RK
11 RGU
FrankieB is offline
post #3 of 15 (permalink) Old 11-09-2015, 10:29 AM
glide69's Avatar
Use a variable pressure clutch works on centfrifugal force no slipping. several options out there. I went with the S&S as I have there 124" powerplant! 132Hp & 134Tq and no clutch slip.
Swomack likes this.
2018 FLTRXS Wicked Red
glide69 is offline
post #4 of 15 (permalink) Old 11-09-2015, 12:35 PM Thread Starter
Not a significant amount of hp Frankie. Only time I notice slip is high rpm 4-5-6 shifts and really only when I'm having too much fun and shift too quickly at WOT. Would you say a heavy duty diaphragm spring would help with that? I'm not concerned with pull weight. Thanks.
post #5 of 15 (permalink) Old 11-09-2015, 12:56 PM
My bike also slipPed a little in the higher gears when I'm getting in the throttle. I got the heavy duty clutch diaphragm spring from Harley. It doesn't cost much and is easy to install. Works just fine.
Straitline
Straitline is offline
post #6 of 15 (permalink) Old 11-09-2015, 02:24 PM
FrankieB's Avatar
I would do the SE spring and see how it holds.
06 RK
11 RGU
FrankieB is offline
post #7 of 15 (permalink) Old 11-09-2015, 02:47 PM
Smarty's Avatar
Yup, SE spring and you will be fine.
Smarty is offline
post #8 of 15 (permalink) Old 11-09-2015, 11:12 PM Thread Starter
Sounds like a plan to me. Thanks guys for the responses.
post #9 of 15 (permalink) Old 12-11-2015, 11:31 AM
I had these same problems and installed a Rivera Pro Clutch, problems solved. Not the cheapest solution but it worked for me.
2011 RGC, 103, tts master tuner, thunderheader, stage 1 breather and woods 777 cams
bigr545 is offline
post #10 of 15 (permalink) Old 12-12-2015, 11:32 AM
I use the HD SE clutch spring and I never had the clutch slip at any RPM or riding situation. I think in most cases the clutch slipping would be a clutch adjustment issue on the 103 or 110 engines no matter what upgrades the bike has.
I also installed the SE clutch plates which eliminates the damper spring and damper spring seat and replaces those parts with full size clutch plates.
09 Touring Service Manual, New Barnett clutch spring bucketlisthd Parts for Sale 3 05-25-2015 09:23 PM
Clutch Diaphragm Spring Wood Parts for Sale 3 01-06-2015 02:07 PM
New clutch pack and diaphram spring Trak350 *General Road Glide Discussions/Pictures 18 02-28-2014 11:59 PM
OEM Clutch Spring 1st Sgt *General Road Glide Discussions/Pictures 17 01-19-2014 12:26 AM
