Stock Valve Spring limit? - Road Glide Forums
 2Likes
  • 2 Post By Hillsidecycle.com
post #1 of 5 (permalink) Old 11-11-2015, 09:53 AM Thread Starter
Ok, I have read anywhere from .530 lift to .600 lift is safe on stock 103 valve spring. Anybody here ever ran a cam with high lift on stock springs? mine is a 2012 103" and the cam has a .579 lift.
smajr85 is offline
post #2 of 5 (permalink) Old 11-11-2015, 11:06 AM
The stock springs will be just fine with .579 lift. In general on a 103 engine any lift over .550 is a waste, a .550 lift will allow the engine to pull in all the AFR it can with no restriction.
post #3 of 5 (permalink) Old 11-11-2015, 11:43 AM
Smarty's Avatar
To clarify what Ironmark is saying, without doing headwork, more compression, bigger throttle body, etc., somewhere around 550 to 570 is all your stock engine with after market performance pipes can fully utilize.
Smarty is offline
post #4 of 5 (permalink) Old 11-11-2015, 03:30 PM Thread Starter
The heads are getting a port and polish job my a local machine shop and i plan on putting the .030 head gaskets on. Thanks guys! I really didn't want to have to spend ANOTHER few bills on springs!
smajr85 is offline
post #5 of 5 (permalink) Old 11-12-2015, 07:09 AM
The port/polish shop sound be the source of that spring info, by rights.
That said, they actually go beyond .600" prior to coil bind, as we have tested them in our spring testers here, but we DO NOT suggest going there.
That spring in the OE HD head is manufactured by Comp Cams.
At .579"(?) you'll be good.
Scott
Swomack and Smarty like this.
Hillsidecycle.com is offline
120R valve spring pressure jodystony Engine Related 8 08-11-2014 08:44 AM
Broke valve spring exracer2002 Do-IT-Yourself 3 04-19-2014 08:17 PM
Zumo 600 speed Limit detection Miceracs Equipment-RG 12 03-17-2012 11:48 PM
weight limit? stevec57 *General Road Glide Discussions/Pictures 3 03-16-2012 08:39 PM
Speed limit on cruise control? Howardsternspenis *General Road Glide Discussions/Pictures 20 05-05-2011 06:39 PM
