Backfires through the exhaust - Road Glide Forums
post #1 of 17 (permalink) Old 11-22-2015, 02:30 PM Thread Starter
Wood's Avatar
The bike: 2010 FLTRX, 55,000 miles, stock engine/ECM/electronics, 2 into 1 exhaust, cat-less stock header. Bought the bike used with 12,000 miles back in 2011.
This is the first time I ran into this problem.
My problem began in mid-November 2015 and occurred the last two times I have gone out riding. 1) I go into the garage for a late morning ride and hit the starter button, the bike starts-up immediately as it always has done; 2) Ride approximately one mile to top off the gas tank. After filling the tank I hit the starter button for the first time and the bike just cranks away, it does not start ; 3) After I wait several seconds I hit the starter for the second time and the bike just cranks away and then backfires loudly through the exhaust, it does not start ; 4) Again after waiting for several seconds I hit the starter for the third time and the bike starts-up immediately as usual; 5) For the rest of the day when I hit the starter button the bike starts-up immediately.
Not sure what to check first (codes, exhaust flange gasket bolts, etc), any insights are welcomed.
Wood is offline
post #2 of 17 (permalink) Old 11-22-2015, 02:38 PM
Try a set of new spark plugs.
EODHOG likes this.
Big_gary is online now
post #3 of 17 (permalink) Old 11-22-2015, 04:08 PM
smitty901's Avatar
Agree plugs first then fuel filter. Check easy stuff first.
smitty901 is offline
post #4 of 17 (permalink) Old 11-22-2015, 04:49 PM
FDR's RGC's Avatar
Battery weak.enough power to spin motor but not enough to start bike.
FDR's RGC is offline
post #5 of 17 (permalink) Old 11-22-2015, 04:57 PM
mocotom's Avatar
If you ride the bike for more than a mile before you shut it off does it still act the same. Your ECM fuel enrichment table for engine warm up may be just slightly lean in the early stages.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 17 (permalink) Old 11-22-2015, 09:04 PM
fastfreddy's Avatar
mine has done that, and strange as this sounds, thats how i know its time for a new compensator, it also will start farting back thru the intake, the bike is on its third comp
fastfreddy is offline
post #7 of 17 (permalink) Old 11-22-2015, 09:28 PM
What type of two n to one? Does it always run rich? Outside temp?
Does your bike deceal pop
^good answers, check for cracked plug first
reds4 is offline
post #8 of 17 (permalink) Old 11-22-2015, 09:56 PM
idahointrudr's Avatar
How many miles are you getting out of those compensators?
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #9 of 17 (permalink) Old 11-23-2015, 10:42 AM
After you try starting the bike and it just cranks over cycle the ignition by turning it off then wait a few seconds then turn the ignition back on and wait for the check engine light to go out than try starting the bike. The ECM may need a reboot for lack of a better term, if the bike starts then it is a ECM issue if the bike doesn't start it may be a mechanical issue.
Check for DTC's but if it was a ECM issue you may not get any DTC's that are related to the problem.
The good news is if it is the ECM in most cases just cycling the ignition will start the bike and the ECM will work as it should so there is no need to replace the ECM unless it fails totally.
post #10 of 17 (permalink) Old 11-23-2015, 04:32 PM Thread Starter
Wood's Avatar
Thanks for all of the input!
The battery is good and I occasionally have a minor decal pop.
Since the fuel filter is due for a change, I'll change the fuel filter first. If that doesn't work I'll try cycling the ignition switch and then change the spark plugs. Won't be able to do this work until early December, I'll provide some feedback then.
Thanks again, and enjoy your Thanksgiving.
Wood is offline
2015 RGS backfires stock Mach1 *General Road Glide Discussions/Pictures 10 06-27-2015 04:26 PM
New build, oil out through exhaust?? DONVITO Engine Related 30 11-30-2014 01:42 AM
HD Download...It Backfires A LOT Bottle Cap ECM/Fuel Management systems 8 06-09-2012 04:44 PM
05 Backfires through the Air Cleaner mikek53 Troubleshooting for Road Glides 8 02-26-2012 12:19 PM
Listen to CB through Fairing Speakers? Timinfla2 *General Road Glide Discussions/Pictures 18 05-26-2011 05:04 PM
