Thoughts on possible engine mods - Road Glide Forums
post #1 of 3 (permalink) Old 11-23-2015, 08:05 AM Thread Starter
Bigfoots03hd's Avatar
Question Thoughts on possible engine mods
I recently posted about doing Stage IV but I've been rethinking keeping my current cams Woods Tw-555 so I've been researching and talking and asking questions about going this route changing pistons to 10:1 and a set of CNC factory heads. Give me your thoughts and opinions on this setup. Bike is 2012 RGC with Woods TW-555 cams, Vance and Hines power duals header, Rinehart slip ons, SE Ventilator AC, SE race tuner. Thanks
Bigfoots03hd is offline
post #2 of 3 (permalink) Old 11-23-2015, 08:32 AM
09Sharknose's Avatar
I went with stage IV. Very happy with it.
09Sharknose is offline
post #3 of 3 (permalink) Old 11-23-2015, 08:42 AM
Smarty's Avatar
Your old heads polished and ported with street port or a mild performance port with a 1.9" valve and your old pistons intake valve relief enlarged to allow for the new valve size and a .030 cometic head gasket should get you what you searching for with the Woods 555 cam. It should put your compression around 10:2-1 or so. Even better, have the heads cc'd after the port and valve changed out and see where you are. You should be looking for around 83CC's. That with the .030 head gasket and a good tune should really wake up the 555 cam. You don't say what you are looking for with your build or what you expect. Kind of let us know that too. That can change what type build you do.
Smarty is offline
ENgine builders your Thoughts New HD motor? Drago's or Hillcountry Tofast4u Engine Related 0 08-24-2016 11:44 AM
Ready for engine mods, which direction? LM1976 Engine Related 26 05-02-2014 07:23 PM
"Too early" for engine mods? FlyByWire Intake and Exhaust 20 06-10-2013 09:55 AM
Engine Mods OldNerdGuy Engine Related 15 05-19-2012 09:57 PM
Thoughts on a few Mods tj316 *General Road Glide Discussions/Pictures 11 01-15-2012 06:26 PM
