10 mm taylor sprial wrapped racie plug wires. - Road Glide Forums
  • 1 Post By Desertwndrr
post #1 of 7 (permalink) Old 11-29-2015, 02:48 PM Thread Starter
I have a set of the Taylor plug wires. When I installed the cams my dyno guy said to take them off cause theycaused some kind of error code. Does anybody no what this code is and how it affects the bike. 2013 Rg ultra with 57 h cams
Straitline is offline
post #2 of 7 (permalink) Old 11-29-2015, 03:24 PM
Desertwndrr's Avatar
These bikes use the stock ignition system and stock plugs to sense predetonation. Changing the characteristics of the ignition system throws things out of whack. Go back to stock and it will run better.
JayKS likes this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #3 of 7 (permalink) Old 11-30-2015, 06:30 AM
We did a battery of dyno testing with wires many years ago.
Results were...................................nothing to be found.
OEM wires are just fine.
Scott
Hillsidecycle.com is offline
post #4 of 7 (permalink) Old 11-30-2015, 08:43 AM
The Volusianator's Avatar
I've never changes my cams but was thinking of replacing my plug wires with the screamin eagle 10mm phat wires. Any issues there?
The Volusianator is offline
post #5 of 7 (permalink) Old 11-30-2015, 09:18 AM
Lighter wallet.
post #6 of 7 (permalink) Old 11-30-2015, 09:20 AM
Lighter wallet.
Not much lighter!
post #7 of 7 (permalink) Old 11-30-2015, 10:03 AM
No advantage in the the 10mm wires, I used both stock and 10mm wires and IMO you should save your cash for something else.
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 11:17 AM
8 mm plug wires SMOKENJOE Engine Related 1 04-28-2016 06:34 AM
Taylor Sumax Sparkplug Wires Jay2Beers Companies We Can Recommended! 0 04-14-2013 04:00 PM
Sweet Plug Wires cleanrider Aftermarket Accessories 13 03-10-2012 01:29 PM
Splice or Dismantle Wires or Plug? MakeARunMike Controls & Handlebars 17 03-07-2012 05:02 PM
