Take a look at these Lifters - Road Glide Forums
 4Likes
post #1 of 13 (permalink) Old 11-30-2015, 11:52 AM Thread Starter
RGKen's Avatar
So I finally got around to pulling things off my old 2012 CVO 110" motor that is just sitting on my garage floor. Since all you seem to read about is how bad the SE lifters are I thought I would take a look. Not being a lifter expert I welcome any feed back on what you might see in these pics. These lifters have over 47k on them and outside of some light scaring on the outside of the middle section of one or 2 of the lifters they seem to be fine. The rollers are smooth with no signs of wear and they roll absolutely smooth as glass. I know there have been many with issues but here seem to be evidence that not all are that bad. Not trying to put a plug in for MOCO but just wanted to share. ImageUploadedByMotorcycle1448902328.074085.jpgImageUploadedByMotorcycle1448902344.824448.jpgImageUploadedByMotorcycle1448902362.093192.jpg
2018 FLTRXS
RGKen is offline
post #2 of 13 (permalink) Old 11-30-2015, 11:55 AM Thread Starter
RGKen's Avatar
Just to note since I know it will come up. The lifter in the top left corner in the pic that shows the rollers still has oil on it and it shows like it is not smooth. It is very smooth with no scaring.
2018 FLTRXS
RGKen is offline
post #3 of 13 (permalink) Old 11-30-2015, 12:42 PM
They don't look bad but it is hard to tell without a close inspection. A lifter can roll alright on the bearing and the roller should have a little side to side movement, if you can twist the roller then the bearing is going bad.
Also it is hard to see if the lifter collapsed or the spring is going bad without a hands on inspection.
Did you ever use a aftermarket higher lift cam in the bike?? A higher lift cam can put the lifters under more strain which will cause premature failure also stronger valve springs will can cause premature lifter failure.
In general if you keep the cam lift around .555 and you have stock valve springs you shouldn't have any problems with the stock lifters.
RGKen likes this.
post #4 of 13 (permalink) Old 11-30-2015, 05:01 PM Thread Starter
RGKen's Avatar
There is the small amount of side to side movement but I cannot twist the roller at all. I only ran the stock 255 cams in it but even still there was a lot of issues with the lifters in the 110's up to a point and I'm not sure when MOCO change them. These could be better lifters than what they were once putting in. Not a real big deal, I just wanted to post a small success story about the lifters since most only post about the negative. I'll get an indy to look at them but from what I see it looks like they could have gone another 47k but who knows, they won't go back in any motor that I own anyway. If I have lifter issues I will use a fresh set.
I'll tear the rest of the motor apart this week just to see all the damage the failed crankshaft bearing did and to see if the pistons and heads are ok. Kinda fun have an extra motor just lying around to tinker with.
2018 FLTRXS
RGKen is offline
post #5 of 13 (permalink) Old 11-30-2015, 05:25 PM
smitty901's Avatar
You can take most HD stock or SE parts that the internet has nothing good to say about. Repackage them . Rename them as Fist slammer ninja and they would magically become the best in the world.
In order to sell their products many companies go out of their way to feed the anit ND part fever on the net.
Never had a lifter fail not even on an HD with 80K on it.
RGKen likes this.
smitty901 is offline
post #6 of 13 (permalink) Old 11-30-2015, 05:39 PM Thread Starter
RGKen's Avatar
That is pretty much what I believe as well. Paranoia sells a lot of parts for the aftermarket world.
2018 FLTRXS
RGKen is offline
post #7 of 13 (permalink) Old 11-30-2015, 06:38 PM
JacktheBagger's Avatar
I agree on the HD parts quality , plenty of good to great HD parts out there , one person has an issue , then everyone says the part is no good , a feeding frenzy to replace the trashy HD parts ..
Truth be known , most peeps wouldn't know good from bad ...
Many issues can be traced back to someone who thinks they know what they are doing , but really have no business even owning tools , let alone use them ..
Unlike their predecessors , TC's have very little room for error when replacing parts or rebuilding engines ..
JtB
reds4 likes this.
2011 Ultra
JacktheBagger is offline
post #8 of 13 (permalink) Old 12-02-2015, 07:43 AM
Some get lucky, but lifter failure in performance motors is not an internet scare tactic to sell parts. I had SE lifters take out a great running motor, granted it had .625 lift cams, but I know guys with more radical cams and S&S lifters having no problems. There are many documented failures of SE, Harley "C", and Gaterman lifters. The best lifters HD had were the "B" model. Agree with Ironmark, keeping cam lift near stock gives a better chance of no problems. I had 90,000 miles on stock lifters, but that was on a 80" Evo, stock cams (.472 lift), and production back then wasn't in Mexico or China.
rg113 is offline
post #9 of 13 (permalink) Old 12-02-2015, 08:27 AM Thread Starter
RGKen's Avatar
Originally Posted by rg113 View Post
Some get lucky, but lifter failure in performance motors is not an internet scare tactic to sell parts. I had SE lifters take out a great running motor, granted it had .625 lift cams, but I know guys with more radical cams and S&S lifters having no problems. There are many documented failures of SE, Harley "C", and Gaterman lifters. The best lifters HD had were the "B" model. Agree with Ironmark, keeping cam lift near stock gives a better chance of no problems. I had 90,000 miles on stock lifters, but that was on a 80" Evo, stock cams, and production back then wasn't in Mexico or China.
It's all in how you want to look at it. I would say that your statement would be more accurate if you said "Some get unlucky." I know S&S lifters are great but I seriously doubt that they have NEVER had a failure. Sure if you are putting in higher lift cams then why not go with X brand. You are changing from the way the MoCo designed the motor to start with. I know a few guys with 120R's that have higher lift cams (T-man, Woods) than what came in them and still running the SE lifters with no issue as well. If I were building a bike that I wanted to race and had tons of Hp/Tq I would go with one of the big aftermarket guys like S&S because that is what they specialize in and are a proven winner AND they only deal with motors. Not disputing that but for the everyday rider that doesn't put his bike through the ringer it is just not necessary unless you just have money burning a hole in your pocket. MoCo is in the business of selling motorcycles and seems like everything else under the sun. Maybe that's their downfall because they have too many things to worry about but if S&S tried to mirror HD and sell everything they did, you would start seeing the same issues or they wouldn't be able to stay in business. Never said there is never an issue with their parts. Their are but we don't always know how important pieces of information for that contributed to that failure. We all like to bash HD for just wanting to make a buck but are willing to overlook it when the aftermarket guys do it too. If HD were all that bad most of us would be riding another brand of bike and not bashing other people for wanting to go buy an Indian or Victory. There will be as many different opinions on this topic as we have members and it makes for great conversation but for me I love my HD and plan to put as many miles as possible on it. Ride safe guys!
2018 FLTRXS
RGKen is offline
post #10 of 13 (permalink) Old 12-02-2015, 09:50 AM
GlideShark's Avatar
I was one of the unlucky ones with the 110.
GlideShark is offline
New install, Kenwood / JL / Kicker, take a look Husky13 Audio 42 08-05-2015 10:08 PM
Want to see something scary take a look at video. DragoBikeWorks Engine Related 45 02-07-2014 06:28 AM
Fairing gap check. Please take a look. Trip20 Paint & Bodywork Section 8 07-27-2013 07:32 PM
So I Decided to Just Take a Look at the Fairing... Shrug *General Road Glide Discussions/Pictures 11 06-14-2010 02:22 PM
