Anybody Near The Green Bay, WI Area... - Road Glide Forums
  • 1 Post By 9over
post #1 of 10 (permalink) Old 12-01-2015, 08:47 PM Thread Starter
The Volusianator's Avatar
That would be willing to come by and help me remove my rocker box covers and push rod/tappet covers for powder coating? I have beer and cigars...and more of the same if you're willing to help reinstall!
Wade
The Volusianator is online now
post #2 of 10 (permalink) Old 12-04-2015, 01:03 AM Thread Starter
Nobody?
post #3 of 10 (permalink) Old 12-04-2015, 07:49 AM Thread Starter
Originally Posted by PF120 View Post
why cant you do it yourself? its really not a big deal
I'm fine removing them, it's the reinstall that has me concerned.
post #4 of 10 (permalink) Old 12-04-2015, 08:17 AM
Skirmish's Avatar
Eleven years ago I would have helped but the drive is just too far these days. It really isn't that difficult though.
Skirmish is offline
post #5 of 10 (permalink) Old 12-04-2015, 10:46 AM
This is a easy DIY. A HD touring bike service manual for your year is recommended.
1-Pull fuel tank & spark plugs & pushrod tube spring cap retainer
2- take bolts out of rocker covers and remove rocker covers.
3- take bolts out of crankcase breather with 3/8 socket and ratchet there is no need to remove breather from rocker housing.
4- rotate engine until the cam is on the base circle, you can do this by bumping the starter and looking at the rocker assembly at the same time.
5- loosen the 4 rocker bolts using 1/2 inch box end wrench. Alternate loosening the rocker bolts until the tension from the pushrods & lifters is off the rocker assembly.
6- With the rocker bolts completely loose you can lift the rocker assembly and rotate the rockers 1/4 of a turn than you can pull the pushrod right out of the top of the engine. It is best to mark the pushrods intake and exhaust for installation later on.
7- with the pushrods out you can pull the right side rocker bolts out of the rocker assembly and you leave the left side rocker bolts in the the rocker assembly and then you can remove the rocker assembly bringing the assembly out on the right side of the engine.
8- remove rocker box bolts using a 7/16 wrench and remove rocker box.
You can reuse the gaskets if there is no damage to them but new gaskets don't cost much. Also it is hard to get a torque wrench in some places so remember that the bolts are threaded into aluminum and it is easy to strip the threads if you over tighten the bolts, just snugging up the bolt good will be tight enough in most cases.
Installation is easy, just start at 7 and go to 1. This would be a good time to install adjustable pushrod in if you do just follow the instructions included with the pushrods to adjust.
Good luck
post #6 of 10 (permalink) Old 12-04-2015, 06:59 PM Thread Starter
Thanks for the write up, I may just give this a go on my own!
Originally Posted by ironmark View Post
Good luck
post #7 of 10 (permalink) Old 12-04-2015, 07:41 PM
RGKen's Avatar
Just make sure the Powder Coater knows not to PC the surface where the gaskets go or they do not damage those edges in any way. You will develop a leak if they jack up those surfaces.
2018 FLTRXS
RGKen is offline
post #8 of 10 (permalink) Old 12-05-2015, 09:59 AM
Not a problem , give it a go! It is really pretty easy to do just take your time.
post #9 of 10 (permalink) Old 12-05-2015, 12:17 PM
9over's Avatar
Have confidence in yourself. You can do this !
PF120 likes this.
9over is offline
post #10 of 10 (permalink) Old 12-11-2015, 08:48 PM Thread Starter
Good luck
What's the benefit of this? Sorry, I'm a Harley noob.
Congratulations to Falcon, Patriot, Green Bay and Steeler Fans ironmark General Off-Topic Discussions 5 01-17-2017 10:48 AM
WI IL KY MO IOWA WI Road TRIP cvanmete Road Trip Discussions/Stories/Pictures 9 07-24-2013 11:04 PM
Hello from Green Bay,WI Chester New Members Welcome Area 39 07-18-2012 10:49 PM
East bay bay area meet ups BAYBAGGER Organize Rides Here 2 04-01-2012 01:02 PM
Headed to Green Bay for 1st packer game 07Roadie Road Trip Discussions/Stories/Pictures 2 08-28-2011 11:18 AM
