Woods 555 question - Road Glide Forums
post #1 of 9 (permalink) Old 12-02-2015, 09:09 PM Thread Starter
Bigfoots03hd's Avatar
Question Woods 555 question
10:1 or 10.5:1 compression which would be better for the Woods 555 cams I have? Thanks
Bigfoots03hd is offline
post #2 of 9 (permalink) Old 12-03-2015, 06:18 AM
After working with his cams, that Andrews grinds, since 1996, that will optimize at 10.3 cr.
Scott
Hillsidecycle.com is offline
post #3 of 9 (permalink) Old 12-03-2015, 10:42 AM
The TW555 will work just fine with stock compression. Increase in compression will not hurt but it isn't required for the TW555 to work well.
post #4 of 9 (permalink) Old 12-03-2015, 01:38 PM
equandt's Avatar
I have a 10.25:1 compression pistons with my TW-555 cam. I've had it for 20,000 miles now and it still works good.
2012 FLTRX
2010 FLHTCU
equandt is offline
post #5 of 9 (permalink) Old 12-04-2015, 06:41 AM
The cam is in fact advertised as a "bolt-in".
Yes, it will "bolt-in" under the OEM spring, and no fear of any valve to valve interference. Very true, but not the entire story.
That said, the intake valve closing number is such, that increased compression is IN FACT needed, for that cam to expose the power.
10.25, 10.3 cr is the number, maybe a just tick more in a lighter bike/gearing.
I know this in my sleep, as we have worked with this line of cams in many, many, builds since 1996.
Scott
post #6 of 9 (permalink) Old 12-04-2015, 04:28 PM
Don't want too cause trouble have you look at GMR'S gennis 577? Mild to wild direct bolt in.
dozer23 is offline
post #7 of 9 (permalink) Old 12-07-2015, 06:57 AM
Copy-cam of Mike Rolands Kury 24D.
Scott
post #8 of 9 (permalink) Old 12-07-2015, 09:36 AM
Copy cam? Specs are close but not the same. Looks like the 24 and 577 hold the tourqe longer than the 555?
dozer23 is offline
post #9 of 9 (permalink) Old 12-08-2015, 07:12 AM
The Kury 24D was professionally designed and engineered, by Mike Roland, and brought to market thru Kury.
The other cam had a couple of the numbers moved a bit as not to be an exact blatant copy.
Other outfits have done the same as history clearly shows.
It is a cut-throat industry without remorse.
Scott
Fuel Moto USA 107 Kit with Woods 555 cams daryl_db Parts for Sale 28 10-22-2014 09:34 AM
Woods TW-555 cams 07 and up pat123 Parts for Sale 1 06-03-2013 10:22 AM
Power Vision map for dragula 2/1 and TR-555 TRQ Cams TXcruiser Map Section 8 04-03-2012 02:20 AM
Tman tr-555 trq cam owners check in TXcruiser Engine Related 17 03-29-2012 09:04 AM
Tman TR 555 TQ 1BigGuy Engine Related 8 12-08-2011 10:49 AM
