Ready for Heads - Road Glide Forums
 3Likes
post #1 of 15 (permalink) Old 12-05-2015, 05:13 PM Thread Starter
Ready for Heads
Ready to finish my stage 4 build but wondering if there are better heads out there for the money than the screaming eagle heads?
2016 Road Glide Charcoal Pearl. 6.5 stereo installed.
Black Thunder Header 2-1
FP3 tuner
LUCKY13 is offline
post #2 of 15 (permalink) Old 12-05-2015, 06:58 PM
Sure there is! I am sure some of the forum sponsors would be able to take your stock heads and modify them. The SE heads aren't bad and they make a good heads to modify for peak performance.
I personally am not a big fan of head work IMO they don't give much bang for the buck for normal riding, but if you want to squeeze out all you can out of a engine than head work helps.
post #3 of 15 (permalink) Old 12-06-2015, 06:34 AM
sj01fltri's Avatar
As ironmark said you would be better off having your heads reworked,do your home work when it comes the shops that offer porting work,dont get hung up on numbers,when i had my heads done on my 01 95 inch RG i went with a local guy.He said that if i wanted bragging numbers on the flow bench thats what he could give me.But he said that my heads would work better if we worked with the specs of my cams.And that bike ran fantastic.So go with who makes sense to you and you are comfortable with.We have some Engine experts on this site who can help you out with any questions you may have.Good luck.
9over likes this.
sj01fltri is offline
post #4 of 15 (permalink) Old 12-06-2015, 09:13 AM
It is the heads that make the power and it is the cam that dictates where in the rpm range the power will be. The porter decides if the flow is more for top end power or for low and mid range. Head work is not just for top end power. it has a direct effect on all the rpm's. anymore questions just ask IMO
dsvracer1 is offline
post #5 of 15 (permalink) Old 12-06-2015, 11:02 AM
The cams have more to do with power than head work does. The cams determine the lift and duration of the valve lift and the timing of the engine.
The heads house the valves and spark plugs and rocker assembly and that's it. By putting in bigger intake and exhaust valves it just allows the pistons to draw in AFR or expel exhaust gases with less restriction which result in a minimum HP/torque gain. The port and polish just allows the gasses to flow smoothly when entering/exiting the engine.
In general a engine such as a 103 can only draw in so much AFR on the intake stroke and that will not change unless you pressurize the intake with a turbo, the size of the valves will not change the volume of AFR in the cylinder. Larger valves just allows the energy (3 to 5 ft lbs of torque on a 103) it takes to draw in AFR or expel exhaust gas to be transferred to the rear wheel.
Pull up the dyno sheets on a 103 engine (Fuel Moto has a good dyno section) and compare dynos on 103 builds. The biggest power gain is from the cam and the smallest power gain is from headwork.
Of course the bigger the engine the bigger the power gain but the percentage of gain is pretty much the same.
It is your bike and if you want to get maximum performance then head work will work well for you. If you just cruise do general riding /touring head work isn't really necessary.
This is JMO I been on both sides of this fence and for my riding style the big build was a big waste of money for me.
post #6 of 15 (permalink) Old 12-06-2015, 11:29 AM
All one has to do is google " cylinder head porting" to see the value obtained by this process. Read what Dennish, Vizard, Mondello and others say about it. A cam all by itself, just as worked heads all by themselves don't tell the whole story. A build with proven components, (heads, cams, compression, exhaust, etc.) working in concert is what makes power across a broad range, low, mid and high.
Smarty likes this.
rg113 is offline
post #7 of 15 (permalink) Old 12-06-2015, 11:24 PM
I have T Man Pro turning heads with intake 2.000 & ex are 1.610 vavles and T Man 600 cam.It breathes very good.
roadglide600 is offline
post #8 of 15 (permalink) Old 12-07-2015, 12:16 AM
dynoguymn's Avatar
Im not positive you truly understand the role that the heads play in your total engine package.
Your over emphasis on cams is flawed. Cams, although important are only one component of the total system. Such things as port velocity and quench are often overlooked. To prove my point; Go to the hardware store and go to the PVC pipe section and pick up a 3" diameter pipe and then a 1.5" diameter pipe, both a few feet long. Hold your hand over the end and blow out. Which pipe were you able to feel your breath through? Which one is more forceful in pushing your hand away? Of coarse it'll be the smaller pipe! This is a gross oversimplification of the importance of proper porting but you get the idea none the less.
dynoguymn is offline
post #9 of 15 (permalink) Old 12-07-2015, 06:44 AM
Port shape, size, valve shape, size, seat angles, etc, all come togather to establish a good/great cylinder head, and yes, good cylinder head work enhances from bottom to top.
Our in-house(not all shops can claim that, btw)cylinder head program has 5 different levels of T/C work.
Happy to get you going down the right path.
Scott
Hillsidecycle.com is offline
post #10 of 15 (permalink) Old 12-07-2015, 09:56 AM
Remember that an engine is just a big air pump. The more air you move, the more power from the pump. Head work is done to help with the atomization of the fuel mixture and to increase the efficiency of the combustion phase of the pump. Better atomization of the fuel mixture will result in more of the fuel being ignited and a greater potential of increased air flow through the pump.
RazorHog likes this.
jim underwood is offline
Bike almost ready for paint What color aargh Harley328 *General Road Glide Discussions/Pictures 22 03-23-2011 10:01 PM
Getting ready for my next purchase JuicedHD New Members Welcome Area 17 03-20-2011 04:30 PM
Its almost ready HogWild Road Glide Specific Discussions 74 02-22-2011 02:12 PM
Ready to ride in Indiana screamglide01 New Members Welcome Area 12 12-30-2010 11:07 PM
Road Glide FLTRX 2010 - Almost Ready 440sundancer *General Road Glide Discussions/Pictures 20 05-06-2010 07:05 PM
