engine upgrade verification - Road Glide Forums
post #1 of 7 (permalink) Old 12-12-2015, 10:44 AM Thread Starter
oh4nighttrain's Avatar
I recently purchased a 2005 RG and was told it had a stage 2 upgrade, is there any way to verify this? It was a purchase from a car dealership and they told me there was no documentation to verify the upgrade. I do know that it is quicker than my friends 103 Ultra Classic.
oh4nighttrain is offline
post #2 of 7 (permalink) Old 12-12-2015, 11:20 AM
lil chief's Avatar
The only way of verifying, besides tracking down the previous owner(s) & asking, is to take it apart and look at the part numbers on the cams, pistons, take measurements of the bores/pistons etc. I don't think I'd do that though, unless I was going in to do more engine work.
Lil Chief
lil chief is offline
post #3 of 7 (permalink) Old 12-12-2015, 11:21 AM
There is no real way to tell unless you tear into the bikes engine.
A stage 1 is pretty easy to check because it is just a air intake and exhaust upgrade.
A stage 2 would include a cam and you would have to tear into the cam chest and pull the cams to get a part number. It isn't a bad idea to open the cam chest and check the cam chain tensioners and install new cam bearings anyways.
To check and see if you have the 95 inch big bore kit you would have to pull the heads and check the piston size which isn't worth doing IMO.
If your bike runs good and you're happy with it then just leave it alone but doing the maintenance in the cam chest would be a good idea just for peace of mind.
post #4 of 7 (permalink) Old 12-12-2015, 01:46 PM
maybe someone can say for sure but I think if the work was done at a dealer then there should be record of it that can be pulled by the vin
2001 Road Glide Jade Sunglo , carb and stock
Eagle is offline
post #5 of 7 (permalink) Old 12-12-2015, 05:28 PM
The work record for performance upgrades can only be pulled up at the dealer that performed the work so you would have to find the dealer that did the work to get the record. I am not sure but if it was just a performance mod then the work may only be listed under the customer's name depending on the dealer's record system .
Any warranty work and recalls could be found by running the VIN # because those records are available to all dealers through HDs record system.
post #6 of 7 (permalink) Old 12-12-2015, 05:56 PM
fastfreddy's Avatar
a simple compression test could tell ya some n
fastfreddy is offline
post #7 of 7 (permalink) Old 12-12-2015, 06:10 PM
Lil Chief
Yep.
Measure it.
Scott
Hillsidecycle.com is offline
Part number verification Wharf Rat *General Road Glide Discussions/Pictures 6 05-23-2017 05:43 PM
Odometer verification Elwha101 Tech Area 22 06-13-2016 04:06 PM
Cam/engine upgrade... ZachB Engine Related 10 04-04-2012 02:12 PM
Engine Upgrade ??????????? TearlessTom *General Road Glide Discussions/Pictures 18 11-10-2011 09:09 PM
Weigh in on Potential Engine upgrade mtglide *General Road Glide Discussions/Pictures 5 09-05-2010 06:15 PM
