Adjustable push rod question - Road Glide Forums
post #1 of 18 (permalink) Old 12-13-2015, 10:44 PM Thread Starter
BigNorm's Avatar
I understand that I can pass on taking off the top end if I just cut the stock push rods in half and replace them with the adjustables. But if I plan on taking the heads off anyway to replace the head gasket and have them reworked why do some cams say that adjustable push rods are required? Thank you for your enlightening comments.
BigNorm is offline
post #2 of 18 (permalink) Old 12-14-2015, 03:55 AM
immo2896's Avatar
I'm no expert by any means but here goes. The way I look at it, is the stock non adjustable has a small chance to be the right length. All it would take is the base size of the cam to be different from the stock one, and the pushrod is too long/short. Head gasket thickness could be different, or what if the heads have been shaved a little to clean them up. These 3 variables would make me want to have peace of mind that my valves are adjusted properly.
immo2896 is online now
post #3 of 18 (permalink) Old 12-14-2015, 08:12 AM
Hullhorr's Avatar
In addion to the above, adjustable pushrods will let you precisely set the proper preload on the lifters which I would recommend replacing if doing cams. Some lifters require more preload than others.
2009 FLTR MOP
Hullhorr is offline
post #4 of 18 (permalink) Old 12-14-2015, 08:26 AM
Desertwndrr's Avatar
Adjustable pushrods are NOT required and many people prefer to run the solids. You will want to verify length if you are going to a thinner head gasket and/or a cam with a smaller base circle, but you can run the solids assuming that things check out.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #5 of 18 (permalink) Old 12-14-2015, 08:39 AM Thread Starter
BigNorm's Avatar
Thanks for your help. It seems obvious now but for a while I couldn't grasp it. I do plan on installing a thinner head gasket so adjustables will be necessary. Thank you for your help. How do you adjust preload? I know you don't want to totally collapse the lifter.
BigNorm is offline
post #6 of 18 (permalink) Old 12-14-2015, 08:44 AM
Hullhorr's Avatar
The instructions that come with the lifters will tell you. Pay attention to the "threads per inch" of the pushrods you buy. You tube or Fuel Moto's website has videos on installing the adjustables. It's not hard.
2009 FLTR MOP
Hullhorr is offline
post #7 of 18 (permalink) Old 12-14-2015, 08:53 AM
When a cam maker requires adjustable's it's because the base circle of the cam(s) are different from stock.
Good advice on replacing lifters by Hullhorr. S&S are very good IME.
rg113 is offline
post #8 of 18 (permalink) Old 12-14-2015, 08:56 AM Thread Starter
BigNorm's Avatar
Thanks for the info.
BigNorm is offline
post #9 of 18 (permalink) Old 12-14-2015, 10:09 AM
Smarty's Avatar
They do make perfect fit pushrods for all applications. Adjustable aren't the only answer. Adjustables are nice when you are not sure what cams you may like and change from time to time. Both do the job required.
Smarty is offline
post #10 of 18 (permalink) Old 12-14-2015, 10:17 AM
Spazz's Avatar
Another quick note for insight.. NOT ALL adjustable pushrods can be installed by merely cutting out the solids.... I'm doing the research on this and found some adjustables you can do it this way and others you can't... it depends on the design of the adjustables.
RENO BAGGER AUDIO
Spazz is offline
Push Rod Covers, Tappet Covers, ALL Gaskets FlatOut Sold 4 03-05-2015 12:55 PM
Black Wrinkle Push Rod Covers FlatOut Parts for Sale 4 01-05-2015 12:10 PM
Push rod tubes/lifter block covers, how difficult? longrides *General Road Glide Discussions/Pictures 6 11-20-2013 03:13 PM
How to Install New Cams & Adjustable Push Rods Wildman Do-IT-Yourself 19 11-20-2012 08:00 AM
ss push rod keepers not going to top cestaro Engine Related 0 06-03-2012 04:24 AM
