tap/tap/tap - Road Glide Forums
post #1 of 5 (permalink) Old 12-15-2015, 07:53 AM Thread Starter
tap/tap/tap
Are any of the builders using any of these rocker lock devices?
dozer23 is offline
post #2 of 5 (permalink) Old 12-15-2015, 05:56 PM
I not a builder but do my own wrenching and put them on my 15 RGS
They worked well and installed easily
I would recommend them
Remmag is offline
post #3 of 5 (permalink) Old 12-16-2015, 07:05 AM
We've had good luck with RC-680 Loctite Cylindrical Bonding.
Scott
Hillsidecycle.com is offline
post #4 of 5 (permalink) Old 12-16-2015, 08:27 AM
BigNorm's Avatar
What is it?
BigNorm is offline
post #5 of 5 (permalink) Old 12-16-2015, 09:03 AM
Spazz's Avatar
Some rocker shafts tend to rotate in the housings.. and with the play between the mounting bolts and shafts, they TAP TAP TAP as they twist back and forth. It's most prominently heard between 2600-3000 rpms.
The Rockouts and Rocker Lockers ( virtually same, different companies ) take up the slack between the rocker shafts and bolts prohibiting the back and forth rotation of the shafts... no more TAP TAP TAP
I have the Rockouts waiting... I have have some stuff on order and since I am going in, I may as well install adj. P/rods.
RENO BAGGER AUDIO
Spazz is offline
HELP!->Wire tap on switched circuit 2015RG Crash Tech Area 1 05-09-2015 03:14 PM
Transient Tap/Knock bikepsych Troubleshooting for Road Glides 2 12-07-2014 03:48 PM
loud sound,like a valve tap. CPY84 Troubleshooting for Road Glides 14 06-08-2014 11:38 AM
Where to tap plasma rods into for brake only function? '12 FLTRX modot66 Lighting 2 08-31-2012 01:49 PM
Underseat Tap-in to the Aux circuit? mdwar2005 Tech Area 1 05-09-2011 09:07 PM
