Clutch advice please - Road Glide Forums
  • 1 Post By 1st Sgt
post #1 of 10 (permalink) Old 12-17-2015, 09:35 PM Thread Starter
rustyj671's Avatar
I'm currently running a SE clutch spring on my setup. I'm debating on doing a hydraulic conversion or going back to the stock spring and adding the AIM/FM variable pressure clutch setup.
My end result is having less Popeye forearm after riding in stop and go traffic for a while.
Pros? Cons?
'12 FLTRX ==> PV w/ TT, PM Super Gas A/C, Dragos 580 cams, Fullsac DX pipe and 2" baffles in stock muffs, 18" Badseed bars, Custom Dynamics lighting, Dunlop AE tires, Aquatic Audio, JL Audio amp, Polk speakers, Progressive Monotubes, Alloy Art Stabilizer and Cush Drive, GMR Compensaver on SE compensator, Rush Cycle Pedic seat....all thanks to this forum.
rustyj671 is offline
post #2 of 10 (permalink) Old 12-17-2015, 10:03 PM
1st Sgt's Avatar
Not one of your listed choices but I went with a "Clutch Wiz" after installing a Barnett extra plate clutch kit and I'm quite happy with it.
Taccone likes this.
1st Sgt is offline
post #3 of 10 (permalink) Old 12-17-2015, 10:36 PM
NorCal's Avatar
Pros? Cons?
after installing cams and a 2 into1 my clutch was slipping in 4, 5 & 6. I did not want a harder clutch pull, as you have experienced, and went with the AIM variable pressure clutch setup. Took care of the the problem.
NorCal is offline
post #4 of 10 (permalink) Old 12-17-2015, 11:34 PM
Desertwndrr's Avatar
Bandit Sportsman.
This clutch has so much surface area that you can set it up much lighter than stock and it will hold solid.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #5 of 10 (permalink) Old 12-18-2015, 12:04 AM
hd4cruzin's Avatar
+1 on the AIM VPC. I also installed cams and have used the AIM/VPC ever since I had a 95" setup in my old bike. I'm using stock clutch spring with no slipping and have over 100/100.
You won't be sorry and no Popeye arms either. lol
2012 FLTRX BBP
hd4cruzin is offline
post #6 of 10 (permalink) Old 12-18-2015, 05:08 AM
FrankieB's Avatar
Pros? Cons?
What to do will really depend on at what RPM the stock set up was slipping at. Most of the variable pressure plates don't start working until 3-4 thousand RPM's. If you go hydraulic, I would see if I could find one to try before I bought one, the hyd. conversion on my RK is actually harder to pull then the stock clutch, but that could be from the master cyl. bore size on mine.
06 RK
11 RGU
FrankieB is offline
post #7 of 10 (permalink) Old 12-18-2015, 07:44 AM
On my 113" I used a hydraulic actuated stock clutch with a VPC 84T, held 133 tq no problem. Easy pull even at high rpm.
rg113 is offline
post #8 of 10 (permalink) Old 12-18-2015, 08:40 AM
'05Train's Avatar
Had one on my Andrews 57-equipped CVO, along with the Barnett +1 and the heavier spring. I ran through that sucker all the time. Ended up taking it off and dealing with the heavier pull.
'05Train is offline
post #9 of 10 (permalink) Old 12-18-2015, 12:48 PM
glide69's Avatar
I run a S&S vpc with a energy one extra plate clutch pack she holds 132/134 no problems.
2018 FLTRXS Wicked Red
glide69 is offline
post #10 of 10 (permalink) Old 12-19-2015, 10:06 PM Thread Starter
rustyj671's Avatar
I ordered the AIM/Fuel Moto this morning, then I went out to the shop and put the stock spring back in. I forgot how easy it is to pull. I just have to remember to be easy on it until the new parts get here.
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 10:51 AM
Cardo Scala Rider advice please pab Aftermarket Accessories 39 07-25-2012 09:10 PM
Decision....or not...a little advice please ? mastergunnera8 *General Road Glide Discussions/Pictures 33 02-04-2012 07:41 AM
Speaker advice please! speedjunkie Audio 11 09-13-2011 08:38 PM
Luggage and packing advice please!! Ma$$hole *General Road Glide Discussions/Pictures 28 08-02-2011 04:43 PM
