Gear driven Cam for 15 FLTRXS - Road Glide Forums
 4Likes
post #1 of 11 (permalink) Old 12-20-2015, 10:41 PM Thread Starter
RoadglideMike12's Avatar
Has any one installed or been using SS gear driven Cam's in There new Bikes I am interested?
RoadglideMike12 is offline
post #2 of 11 (permalink) Old 12-21-2015, 10:22 AM
Don't waste your money! The gear drive cams where fine for the older 88 inch bikes but they aren't that good for the new bikes.
First of all you can't have a crank runout that exceeds .004 and the crank run out on the new bikes are in HD specs up to .012 so if your crank runout is over .004 you will grenade the gears.
The chain drive with the hydraulic cam chain tensioners are pretty much a bullet proof setup and the bike will run trouble free for a long time just the way it is.
hook likes this.
post #3 of 11 (permalink) Old 12-21-2015, 10:23 AM
Smarty's Avatar
I would not go there on these later model bikes. The runout almost always is more the the allowable amount to run gear drives. Also, with the newer cam plate designs and the hydraulic tensioners, the power loss is minimal because the correct pressure is being applied to the cam chain. I run gear drive on my 04 and it does great but back then Harley kept tighter specs on the crank runout.
Smarty is offline
post #4 of 11 (permalink) Old 12-21-2015, 12:02 PM
Hullhorr's Avatar
As the others have already said don't go with gear drive cams unless or until you decide to have the crank trued.
nsbohall and Smarty like this.
2009 FLTR MOP
Hullhorr is offline
post #5 of 11 (permalink) Old 12-22-2015, 07:15 AM
If the TIR on the pinion shaft is .003", then you can use a gear drive set up.
IF the crank sissors, you'll hear a whine that'll be in cadence with the engine, and .004" will not grenade the gears.....it takes much more than that.
IF it did happen, and was ignored, the large gear will loose several teeth, in the worst of circumstances.
Scott
Hillsidecycle.com is offline
post #6 of 11 (permalink) Old 12-22-2015, 07:53 AM
HellInABucket's Avatar
But here's the question then. Whats the upside of gear driven cams given the reliability now of chain driven?
Scott
HellInABucket is offline
post #7 of 11 (permalink) Old 12-23-2015, 05:05 AM
The upside of a gear drive set-up is 1) dead-balls valvetrain timing accuracy, 2) no more worries in regards to wear on the hydraulic chain shoes as they are now gone, and 3) increased power, as we performed back/back testing over a decade ago, and the gear drive set-up had shown 2 1/2-3 1/2 hp and torque accross the board, all else same/same.
Scott
post #8 of 11 (permalink) Old 12-23-2015, 10:40 AM
Save your money, the newer chain drives are very good, quiet too. S&S only makes 3 gear sizes, so one could end up with more noise than the chain set up.
rg113 is offline
post #9 of 11 (permalink) Old 12-23-2015, 11:51 AM
Scott
I buy 1 and 3, 2 isnt really an issue any longer.
I think there are other variables in valve train accuracy - the accumulation of tolerances of all the parts, and pushrod adjustment, but I get what you're saying.
post #10 of 11 (permalink) Old 12-23-2015, 12:27 PM
Sleepybagger's Avatar
Running S&S 635G's in my 113 with a S&S crank. At idle no more noise then the SE259's made before I went adjustable pushrods. Off idle and running up they're quiet. I prefer gear drive cams for consistent valve timing for tens of thousands of miles. Gear drive vs chain drive: thank God we still have freedoms.
Sleepybagger is offline
'15 FLTRXS Stage 1 Sethjamto Dyno Results 8 10-15-2014 09:35 PM
10" Yaffe OEM Monkey Bars '15 FLTRXS ShortBus453 *General Road Glide Discussions/Pictures 10 09-25-2014 09:01 PM
S&S 551 gear driven cams Loner Intake and Exhaust 18 12-19-2012 07:37 AM
Gear driven cams Loner Engine Related 5 09-04-2012 10:19 PM
