Need advice from the wrenching gurus.. S&S 117 Build - Road Glide Forums
post #1 of 25 (permalink) Old 12-23-2015, 11:42 AM Thread Starter
BDMastiff's Avatar
In addition to my Road Glide I have a 1996 Fatboy. I swapped the original engine for a 2008 S&S 117 EVO. I did head work (Branch O'Keefe) and cams. My bike has difficulty starting at times and often leaves me stranded. I always give the throttle a few pumps and open my enricher before turning it over. The bike chugs before starting. It has a single fire ignition and I often get a backfire that sounds like a gunshot. I'm always able to get if going if I jump start it but that's not a solution to my problem. I'm thinking that I may need a higher torque starter. I don't want to invest in a new starter if that's not the issue. Any advise or thoughts are appreciated.
1996 Fatboy
BDMastiff is offline
post #2 of 25 (permalink) Old 12-23-2015, 12:04 PM
You need to wire a double relay for the starter and compression releases assuming you have ACR's. That's what I did on the 124. Starts every time without a problem.
HogPro is offline
post #3 of 25 (permalink) Old 12-23-2015, 06:17 PM Thread Starter
BDMastiff's Avatar
Thanks for the input. Yes, I have ACR's
1996 Fatboy
post #4 of 25 (permalink) Old 12-23-2015, 06:47 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
Plugs
It may sound like a stretch but a set of plugs might do it, or help at least.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #5 of 25 (permalink) Old 12-24-2015, 07:09 AM
We've re-built many of the low-compression/emmission S&S 117"s to real fire-breathers. 130/135 are the numbers we like to see prior to calling the customer for pick-up.
Once tuned they start instantly.
Perform a compression test on both cylinders, and a leakdown test would also be benificial.
S&S carb with what jets? Bored? Thunerjetted?
What adjustable ignition was used once the engine work was established?
Happy to help.
Scott
Hillsidecycle.com is offline
post #6 of 25 (permalink) Old 12-24-2015, 09:14 AM
smitty901's Avatar
Needs a good tune also.
smitty901 is online now
post #7 of 25 (permalink) Old 12-24-2015, 10:43 AM
Find someone with a dial back timing light. Most say a stock Evo should be timed at 35 deg., IIRC S&S suggests 30 deg. for the bigger motors. Check with S&S as it's been a number of years since I had a S&S crate motor. You know! CRS.
rg113 is offline
post #8 of 25 (permalink) Old 12-24-2015, 06:20 PM Thread Starter
BDMastiff's Avatar
Happy to help
Scott
Super G carb but I don't remember which jets I used. I rejetted a couple of times. I'm using the Thundermax ignition. I did the work a few years ago and I don't remember all the specifics. It was a bear fitting the engine into the FB frame and we took a few short cuts to make things work out. I'm gong to have to look deeper into the specifics.
Currently timed at 35 degrees. My problem may be as simple as a timing issue. I'm a novice mechanic and most of my experience with with EFI bikes. I got some software from Thundermax but I'm not experienced enough to know how to use it; especially on a carbureted bike.
1996 Fatboy
post #9 of 25 (permalink) Old 12-28-2015, 07:06 AM
Happy to help however we can.
Scott
post #10 of 25 (permalink) Old 12-28-2015, 09:01 AM
09Sharknose's Avatar
BDMastiff- would the 117 you put into your fatboy happen to be the stock engine from your mastiff? Just curious....
09Sharknose is offline
Speaker and amp gurus? Need help! jp374 Audio 18 04-12-2016 05:45 AM
attention Audio gurus need HELP Jims79FLH Audio 10 08-26-2015 10:08 PM
117" build or 124" S&S glide69 Engine Related 13 07-02-2015 07:00 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 10:31 AM
Rookie wrenching: my build part deux Dmize Road Glide Builds-Document your builds HERE --NEW 75 04-10-2014 10:53 PM
