Cam crank locking tool question - Road Glide Forums
 3Likes
  • 1 Post By ironmark
  • 1 Post By Smarty
post #1 of 10 (permalink) Old 01-03-2016, 12:42 PM Thread Starter
BigNorm's Avatar
Will a cam crank locking tool for a 96 fit a 103? I think the bottom ends on these motors are the same but I thought it would be safe to ask before buying the tool. Thanks. NORM
BigNorm is offline
post #2 of 10 (permalink) Old 01-03-2016, 01:13 PM
MightyWhitey's Avatar
Hopefully someone with some real knowledge will jump in here for you. All I can say is I ordered one for a 96" thinking the same as you but I can't get the damn thing to fit. Should have done what you're doing, asked for advice.
MightyWhitey is offline
post #3 of 10 (permalink) Old 01-03-2016, 01:30 PM Thread Starter
BigNorm's Avatar
I may just have a friend sit on the bike with the brake on but if I could get that locking block for 20 bucks I may just go with that instead.
BigNorm is offline
post #4 of 10 (permalink) Old 01-03-2016, 04:52 PM
Desertwndrr's Avatar
The cam crank locking tool came in two flavors, 2006 & prior, 2007 & later. I've done cam swaps by holding the brakes but it is much nicer to use the correct tool.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #5 of 10 (permalink) Old 01-03-2016, 08:10 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
The short answer is yes, it should, since the blocks are '06 and earlier and conversely '07 and up. If I didn't have my bikes nestled in for winter I could pull my 103 cam cover and check.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #6 of 10 (permalink) Old 01-03-2016, 08:36 PM
Maybe It just wouldn't line up where it was. Glad somebody cleared it up.
post #7 of 10 (permalink) Old 01-03-2016, 10:12 PM
Smarty's Avatar
Yes it does work. No problem at all.
Smarty is offline
post #8 of 10 (permalink) Old 01-04-2016, 10:33 AM
I never used one, I just put the bike in gear and held the brake down with one hand and loosen/tighten the bolts that way.
The bolts aren't that tight anyways the cam sprocket bolt is only torqued to 34 ft lbs and the crank sprocket bolt is only torqued to 24 ft lbs.
Smarty likes this.
post #9 of 10 (permalink) Old 01-04-2016, 11:17 AM
Smarty's Avatar
Sounds like I do it too. On the primary side I use a composite hammer handle and put it on the chain and wedge it into the teeth when I'm breaking it loose. Of course, I've also cut a piece of flat stock cut to length that goes at about 60 degree angle between the clutch hub teeth and the compensator teeth. Easy to make.
ironmark likes this.
Smarty is offline
post #10 of 10 (permalink) Old 01-04-2016, 02:14 PM
The primary locking tool is easy to make out of a piece of 1/4 x 1 1/4 flat stock.
You definitely need to lock the primary to loosen /tighten the compensator and clutch hub because the torque values are much higher.
Smarty likes this.
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 09:03 AM
big crank or mega crank battery Onthehunt49 General Off-Topic Discussions 7 04-10-2016 06:27 PM
Stock crank vs. S&S crank HDBAGR Engine Related 11 05-23-2015 04:21 PM
primary locking tool rlaf75 Do-IT-Yourself 4 11-06-2014 05:48 PM
Snapon locking ring tool ironmark *General Road Glide Discussions/Pictures 1 07-11-2011 11:53 PM
