New RG ultra...Too much vibration - Road Glide Forums
post #1 of 23 (permalink) Old 01-06-2016, 07:46 PM Thread Starter
Just recently picked up my new FLTRU. Had the dealer install V&H power duals, raider mufflers w/quiet baffles, ventilater ac, and SE race tuner. Was noticing a little more vibration than normal from the get go. At the first wash around 100 miles, I noticed one of the heat shields was touching the tranny cover. Took it back and they readjusted it. Did not make any difference.
This vibration starts at approx. 2K and gets worse with rpms, any gear, any speed, even in neutral. It's a buzzing type vibration and is felt in the handlebars, seat, shifter, and clutch and brake handles. After two rides of around 150 miles I felt like I had been on an ironhead sporty. At this point I should mention that I've been riding Harley touring bikes ( EG's ) since 2002 and have over 100k miles on them and have been riding two wheels for 40 years. I've never had one that felt like this, not even close. It currently has 700 miles and feels like it's getting worse instead of better.
I've looked closely for any other contact w/exhaust but don't see any. At delivery the dealer I think used a stage one flash for temporary use until I get it on the dyno, but it's running pretty good so I don't feel like its a tuning issue. I absolutely love this bike. Compared to the batwings the handling is unbelievable.
My fear is getting the "they all do that" from HD, or it's within spec.
Any ideas ? Anyone deal with this issue? Telling someone my Harley has a vibration sounds like the start of a good joke.
I will take it to the dealer soon, but just wanted to get a few more miles to monitor if it's getting any worse.
GCSuper is offline
post #2 of 23 (permalink) Old 01-06-2016, 08:07 PM
'05Train's Avatar
You know it's not right....The dealer installed the parts; take it back and make them fix it.
It's impossible to diagnose something like this over the internet. Could be anything from the brake lever touching the headpipe to a slipped crank.
'05Train is offline
post #3 of 23 (permalink) Old 01-06-2016, 08:59 PM
Smarty's Avatar
I agree 100%. My 15 and now my 16 are smooth as silk. Differently something going on. Once on my 04 Ultra, the D&D Fatcat header pipe was touching the footboard bracket only after I was on the bike and in gear riding. I searched and searched for the vibration. Finally I saw some marks on the pipe. What I finally figured out was when in gear and moving, the belt put enough torque on the engine to pull it over just enough to touch the footboard bracket. I loosened the bracket on the transmission for the pipe, used a big screw driver and moved the pipe and tighten the bracket back up. Never a vibration again.
Smarty is offline
post #4 of 23 (permalink) Old 01-06-2016, 09:47 PM
09Sharknose's Avatar
If it's a true vibration, your heat shield touching the tranny wouldn't produce that.
On the other hand, if it's a rattling noise, check the center bolt that attaches your air cleaner to the bike. If it's loose, it'll shake. It happened to mine, I thought my engine was falling apart.
09Sharknose is offline
post #5 of 23 (permalink) Old 01-06-2016, 10:01 PM
Swomack's Avatar
Like already stated above, take it back and have them fix it.
They need to make it right.
Good Luck
Swomack
My Gallery / Click Below Link
Swomack is offline
post #6 of 23 (permalink) Old 01-07-2016, 05:39 AM
Tuning issue?
Check all engine mounting points?
Or lastly, the crank is sissored?
Scott
Hillsidecycle.com is offline
post #7 of 23 (permalink) Old 01-07-2016, 09:04 AM
My 2015 RGS vibrated with a "canned map". Once I got a proper dyno tune, smooth as glass.
Note: Dealers don't always allow enough time for techs to perform a thorough tune. I trailered mine to Doc's in Florida.
rg113 is offline
post #8 of 23 (permalink) Old 01-07-2016, 09:55 AM Thread Starter
Originally Posted by Hillsidecycle.com View Post
Tuning issue?
Scott
Don't really think it's tuning and mounting points have been checked. Hoping it's not the latter, but I'd rather it happen now than out on the road somewhere later.
GCSuper is offline
post #9 of 23 (permalink) Old 01-07-2016, 10:14 AM
Smarty's Avatar
Exactly, only touch the frame by way of footboard brackets is what I was talking about. The motor and transmission is rubber isolated from the frame, etc.
Smarty is offline
post #10 of 23 (permalink) Old 01-07-2016, 10:16 AM
Smarty's Avatar
Read the post again, never said touching the tranny, the mount is on the tranny that I loosened to get the pipe away from the floorboard brackets.
Smarty is offline
How much vibration is excessive. KennyD104 Engine Related 11 09-24-2016 10:23 AM
Decel popping - how much is too much? Methos1979 Intake and Exhaust 18 10-14-2015 04:58 PM
How much noise will too much runout cause? thedrill Engine Related 18 02-27-2014 03:52 PM
How much is too much...or is there such a thing? Chaz Audio 6 09-26-2012 03:49 PM
Too Much OIL rookie racer Troubleshooting for Road Glides 5 05-03-2010 08:25 PM
