117" Drop In - Road Glide Forums
 2Likes
post #1 of 19 (permalink) Old 01-16-2016, 10:09 PM Thread Starter
117" Drop In
Was at the local dealer this evening, owner said the factory just released a 117" drop in for 4" bore 110" ers. Don't know compression or other details yet.
rg113 is offline
post #2 of 19 (permalink) Old 01-16-2016, 10:54 PM
Ohiobellboy's Avatar
Read this on the CVO site a little while ago. Could be interesting depending on cost and reliability.
One other thing it makes me wonder about. Will the 110 become the standard engine and the 117 a CVO engine?
A.K.A OBB
Ohiobellboy is offline
post #3 of 19 (permalink) Old 01-17-2016, 08:29 AM Thread Starter
Compression is 9.9:1, flat top pistons. I like that. With some port work on the 110 heads, should be a runner.
rg113 is offline
post #4 of 19 (permalink) Old 01-17-2016, 09:09 AM
09Sharknose's Avatar
I'm still holding out hope that 110 will be standard and the 120st or something similar will be the CVO.
RGKen likes this.
09Sharknose is offline
post #5 of 19 (permalink) Old 01-17-2016, 09:37 AM
That would be a nice option too. Historically, the CVO engine has been 7 CI over the non CVO engine.
88" - 95"
96"-103"
103"-110"
A.K.A OBB
post #6 of 19 (permalink) Old 01-17-2016, 05:51 PM Thread Starter
110-117
117-124
RGKen likes this.
rg113 is offline
post #7 of 19 (permalink) Old 01-18-2016, 07:18 AM
Wonder how piston stability will be with the 4 1/8" bore with the OEM taper-top rods?
HD must have confidence in their cranks(?!?)in order to let folks step up to this cubic inch, but then again the Squealin' Seagull kits are not known for robust output.
Scott
Hillsidecycle.com is offline
post #8 of 19 (permalink) Old 01-18-2016, 07:30 AM
Khaotic's Avatar
117" Drop In
Hmmm
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #9 of 19 (permalink) Old 01-18-2016, 08:59 AM Thread Starter
Originally Posted by rg113 View Post
110-117
117-124
124+7=131 LOL
rg113 is offline
post #10 of 19 (permalink) Old 01-20-2016, 06:39 AM
With only 3 more cubes than a 117" drop-on, the 120R's we've seen, have slipped once you step them up.
Different piston weight, affecting the balance factor?
Makes one think.
Only time will tell.
Scott
110 drop in, CVO w/Mods, 117 drop in Lou Dude Dyno Results 1 03-08-2017 08:59 AM
117" build or 124" S&S glide69 Engine Related 13 07-02-2015 07:00 PM
Drop-in kit, is it really a drop in? Transporter Suspensions 10 01-29-2015 01:22 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 10:31 AM
