Wtf!!!!! - Road Glide Forums
 5Likes
post #1 of 26 (permalink) Old 01-23-2016, 01:15 PM Thread Starter
Ouijonbu's Avatar
Exclamation Wtf!!!!!
GLIDERS,
Check this out, my club called for a ride last weekend, very nice day, in North click, so I get geared up, pull bike out started her up. I went to the first stop sign in my hood, stopped, down shifted and took off. The bike bogged down like I wasn't in first. So, no problem, I got on the road and came to a intersection to get on main highway. I tapped down but didn't get any resistance. The gear shifter just went to the floorboar. I pulled into a gas station and parked it, well, I almost fainted...lol. My whole gear shifter had fell out. I mean out whole. I said easy enough, the screw must have vibrated out or broke or something. The screw was totally intact, and was not loose at all. Talked to another rider who has a 15 CVO and he said the same thing happened to him also. So I get it together and get over to my local dealer, they fixed it with no problem and no cost to me, and they had the parts in stock. When I asked why wasn't this a recall they had no answer, apparently it only happens to the bikes that are sold at that store, 100 bikes
so far and counting. Has anybody else experienced this....?
[SIGPIC]2015 RGS and 2011 ZX14-muzzy pipes, PC-5 w/AT. Hyperlink steering damper, 6" in the rear, -1 in front+2 in rear, secondary flies gone, second fan welded, tires have balance beads instead of weights. Nitro instead of air. K&N AF
Ouijonbu is offline
post #2 of 26 (permalink) Old 01-23-2016, 01:40 PM
Chuck1073's Avatar
It's not rare for the shaft that the shift lever rides on to strip it's splines. There are aftermarket solutions. I always try to shift fairly gently, for that reason, rather than stomping on the shifter.
2015 Roadglide - 2007 American Ironhorse Texas Chopper - 1972 XLCH/Ironhead digger - 2003 Honda CBR954RR
Chuck1073 is offline
post #3 of 26 (permalink) Old 01-23-2016, 02:09 PM
Not a uncommon problem, been happening since Harleys been made. HD puts on cheap gear shift rods because they want you to upgrade to a better hemi joint shifter rod for $100+.
post #4 of 26 (permalink) Old 01-23-2016, 02:26 PM
Nordic Berserker's Avatar
Yea happens way too often, on one of my brothers bikes his came off less then a mile down the road on ride home after he bought it
Nordic Berserker is offline
post #5 of 26 (permalink) Old 01-23-2016, 03:14 PM
Redfish-Joe's Avatar
I have fixed a couple of bikes with the stripped heel toe shifter. The heel shifter takes a beating, in my opinion, I removed mine when I first got the bike. 91k miles later never a problem with it. May be something to consider or pay attention how much weight you are applying to the heel.
Redfish-Joe is offline
post #6 of 26 (permalink) Old 01-23-2016, 03:28 PM
BobRG15's Avatar
Identical problem on my 15 CVO. thankfully made it to a dealer, repaired the bike at no cost and on my way. Agree with Redfish-Joe the heel shifter takes alot of abuse.
Mako Fade Shark added Tour Pak with pass backrest-drivers backrest-pass floorboards-saddle bag guards
BobRG15 is offline
post #7 of 26 (permalink) Old 01-23-2016, 04:39 PM
Smarty's Avatar
On the shifter arm that goes on the transmission shaft, it's always a good idea to buy you a grade 8 allen head bolt and replace the bolt that is in it. With the grade 8 you can really cranck down on it without stripping out the allen head. Once you do this, normally you will never have another problem with it. Been a problem with Harley for years.
Caveman likes this.
Smarty is offline
post #8 of 26 (permalink) Old 01-23-2016, 04:56 PM
Ohiobellboy's Avatar
Another fix is to add a small lock washer to that bolt so it will squeeze the shifter arm clamp around the shaft a little tighter.
Smarty and Caveman like this.
A.K.A OBB
Ohiobellboy is offline
post #9 of 26 (permalink) Old 01-23-2016, 06:04 PM
staush's Avatar
wtf ; shifter
Question, what did they do to fix it? My 11 w/ 36k is getting sloppy on the tranny shaft. Bolt is torqued down, no difference, still sloppy. Did they put on a new shifter arm? If so did they pull your primary to install new arm? Saw that someone makes a replacement but don't know how you can get a dremel in there to cut off old arm. Anyone install this new arm?
staush is offline
post #10 of 26 (permalink) Old 01-23-2016, 06:39 PM
FDR's RGC's Avatar
Don't have to pull primary to install new arm. Put a grade 8 bolt in place of the allen,you can crank down on it. Did my 10 RGC 60k ago,still good. I check it every oil change.
Smarty likes this.
FDR's RGC is offline
Batt & Low Fuel light came on WTF Cotton Hill Troubleshooting for Road Glides 1 10-17-2011 08:50 PM
No Cruise Control WTF Cotton Hill Troubleshooting for Road Glides 12 08-15-2011 07:35 PM
Wtf ??? OldNerdGuy *General Road Glide Discussions/Pictures 9 08-06-2011 08:39 PM
Wtf Whatever01 Troubleshooting for Road Glides 19 06-09-2011 01:46 PM
wife said no ........ wtf ? groupw Road Glide Specific Discussions 50 02-25-2011 04:04 PM
