Advice on Throttle body/injectors.... - Road Glide Forums
post #1 of 4 (permalink) Old 01-24-2016, 03:26 PM Thread Starter
turbochrisb's Avatar
So I'm in the middle of my build. Punching my 06 88" out to 98" with a Dragos 2.5 kit with a Dragos 580 cam, headwork and Dragula 2 4 into 1 with quiet 2.55 baffle. 10.5 comp and will be dyno tuning with TTS (Gene Thomison).
My question is regarding upgraded / bored throttle body and / or upgraded injectors. Want can I expect and is it worth it....I don't mind the addl cost if it's actually making hp you can feel. I'm not looking for every last possible hp out of this build.....but I won't leave 5+hp or tq on the table either if I can get it easily. Not too worried about gas milage as I don't do extended trips and even the ones I'd like to do are measured in the 100's off miles, not 1000's.
What do you guys think?
turbochrisb is online now
post #2 of 4 (permalink) Old 01-24-2016, 03:35 PM
Why not call Dragos?
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 4 (permalink) Old 01-24-2016, 04:15 PM Thread Starter
I will tomorrow when he's back in the shop.....just thought I'd tap the collective wisdom of the group since I'm here today.
post #4 of 4 (permalink) Old 01-25-2016, 11:45 AM
Your stock TB is 46mm and it should work well with your build. There a tons of BB build on the 88 engine that bring it up to 95 to 98 ci that run the OEM TB and injectors with no problem.
The TB upgrade won't help your low end or mid range power any it may only help the top end output.
The biggest TB you should go with on that build is the 50mm TB which works well on any engine 110 ci or lower and came stock on the HD 96 ci engine.
OEM 50 mm Throttle Body and Injectors North Star Parts for Sale 1 06-15-2016 11:42 PM
Stock Throttle Body and injectors Bluchevypick Parts for Sale 4 11-25-2013 07:42 PM
New Throttle body and injectors what tools needed ironmark Engine Related 1 01-04-2013 04:29 AM
Should I get a Throttle Body and Injectors?? ironmark Engine Related 6 11-26-2012 07:51 AM
2010 Take offs-Throttle body, Heads, Jugs and much more kopr2020 Classifieds Archive (3 months old+) 4 06-05-2011 10:06 AM
