transmission/clutch help - Road Glide Forums
 3Likes
  • 1 Post By Smarty
  • 2 Post By ironmark
post #1 of 6 (permalink) Old 02-01-2016, 12:57 PM Thread Starter
GroundPounder's Avatar
installed new frictions and steels, and a new compensator ( barnett scorpion ) as i have done before., only this time the bike will not go in gear ( even with bike off, it rolls as though its in neutral, no matter what gear its in) pull clutch lever, with bike on and i get a rattling noise from primary..... readjusted the clutch and still nothing... any helps greatly appreciated.....
2011 Vivid Black RG Custom, 117ci, Yaffe bars, D D Boarzilla, Alpine PDX F-6, 6.5 Alpine R's up front (4) and 6x9 R's in bags, Paul Jr- Rapture Wheels 23/17, monotubes w/ 1" drop, SMT contrast boards and bag latches, Daymakers. 6* PICKARD TREES, rides like its on rails....I'm through, not spending another dime....
GroundPounder is offline
post #2 of 6 (permalink) Old 02-01-2016, 01:20 PM
Smarty's Avatar
Did you readjust the clutch rod after putting the new setup in? You don't have hydraulic, right? IF not, adjust to specs. Loosen the cable up first before adjusting the rod.
Smarty is offline
post #3 of 6 (permalink) Old 02-01-2016, 01:54 PM Thread Starter
i adjusted it at the rod first, then the cable.....rod slipped out on me, thinking maybe the ball bearings at the ramp fell out...
post #4 of 6 (permalink) Old 02-01-2016, 05:21 PM
Smarty's Avatar
That's probably what happened then. That sucks!
Caveman likes this.
Smarty is offline
post #5 of 6 (permalink) Old 02-02-2016, 11:39 AM
If the clutch lever has resistance then the ball & ramp is in working order because it is pushing the pressure plate out as needed.
The rattling noise in the primary is a sign that something is wrong so taking off the outer primary cover and doing a inspection is something you should consider.
You could try adjusting the clutch again but make sure to loosen the clutch cable before adjusting the pressure plate screw.
What is weird is that the bike should go in gear without using the clutch when the engine is off, take a close look at the shift linkage and the shifter splines.
post #6 of 6 (permalink) Old 02-10-2016, 09:54 PM Thread Starter
Stripped the splines off the front pulley...... Geez.
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 09:09 PM
Clutch Wiz vs Burley easy clutch Trak350 *General Road Glide Discussions/Pictures 14 03-11-2014 10:21 AM
Another transmission problem need help on blackbart36350 Troubleshooting for Road Glides 18 09-30-2013 01:48 PM
Transmission service help please!!! jetfixer737 Tech Area 10 08-03-2013 08:28 PM
Rotating noise in clutch/transmission area. Russian Road Glider Troubleshooting for Road Glides 10 08-01-2012 09:11 AM
