Heavy Breather vs. ventilator? - Road Glide Forums
post #1 of 5 (permalink) Old 02-08-2016, 09:42 AM Thread Starter
Is there a noticable performance difference between the 2? I currently have the heavy breather but am thinking about the Ventilator due to wanting to run lowers.
Thanks
oc357 is offline
post #2 of 5 (permalink) Old 02-08-2016, 09:55 AM
! rock103 !'s Avatar
You're not going to see or feel any increased performance from one stage 1 A/C to the next. No matter the manufacturer or design. The difference if any will me very small. IMHO the heavy breather type of intake looks ridiculous. Basically the only difference is "looks".
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #3 of 5 (permalink) Old 02-08-2016, 11:26 AM
sloride's Avatar
Had the Factory Heavy breather on my 2013 CVO RGC. When tuning the bike at Ed's Dyno Difference after installing the TC-24 cams he did a comparison of my heavy breather and a Zippers setup he had. the Zippers made a 4-5 HP gain from 5000 to 6200 RPM and virtually no difference below 4800 RPM
That difference dropped down to 2-3 HP with the pretty black metal cover off the Heavy breather
On a 103 requiring a little less air...who knows???
sloride is offline
post #4 of 5 (permalink) Old 02-08-2016, 11:44 AM
skratch's Avatar
Thanks
if you want to run lowers, the cheaper route is to buy the compact filter. it runs about $80 and will allow you to run lowers. it is tight, but there is about 1/4'' of clearance. now, if you want to run speakers in your lowers, then you'll definitely need to change air cleaners
skratch is offline
post #5 of 5 (permalink) Old 02-08-2016, 12:46 PM
Khaotic's Avatar
A friend has same bike FLTRXS , motor 120ST, clutch Bandit Sportsman, exhaust D&D Boarzilla and same tuner PowerVision and same Tunees J&B Perfomance, He has ventilator and I have the Heavy Breather Elite Premium only differnece besides year 2015 vs 2016. his 125hp 135tq mine 128hp 141tq. I also have 30t trike prmary gear but am told that will not affect dyno #s Oh and I have wrapped baffle.
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
WTT-Black Heavy Breather for Chrome Heavy Breather MAG150 Parts for Sale 1 01-26-2014 06:15 PM
Screamin Eagle Heavy Breather or Billet Ventilator? bear25314 Intake and Exhaust 12 11-15-2013 11:18 PM
HD Screamin Eagle Ventilator vs. Zippers Max-Flow twistr Intake and Exhaust 7 11-09-2013 12:23 AM
HEAVY HEAVY rains now speakers are not working well rob883 Audio 6 06-18-2013 02:32 PM
HD SE heavy breather fitment 03 vs 08 spider445 Intake and Exhaust 5 01-24-2013 08:23 PM
