Valve intake noise/cam overload noise - Road Glide Forums
  • 1 Post By Stick_FSMC
post #1 of 10 (permalink) Old 02-08-2016, 06:53 PM Thread Starter
Ok need some help here please. Have 13 Road Glide Ultra and put 255 cams in it with Adjustable Push Rods. I am getting way to much noise out of Air Cleaner they say Valve Intake noise also heard it called Cam Overload with these Cams.
Trying to get some options to quiet it down. For now put stock Air Cleaner Cover back on to quiet down. I have talked to dealer and they said couple different options. Put in Sreamin Eagle Springs with regular Push Rods. Someone also said retard the timing 4 degrees.
Have heard of this problem with other bikes and never have found a solution but some say they just ignore it not me its to loud.
Guess main questionis it worth changing Springs. I am not interested in changing Cams.
Thanks for any advice.
2013 Road Glide Ultra,255 Cams,SE Heavy Beather,Power Duals with Monster Oval slip ons,Chrome Werks +2 bars,Windvest 15" Shield,Willie G add ons,Le Pera Daddy Long Legs seat,C&C Fastback seat,Chrome Forks,Painted Inner fairing.
Budd559 is offline
post #2 of 10 (permalink) Old 02-08-2016, 07:07 PM
Springs and solid pushrods will not do anything . Its due to cam overlap and the electronic throttle body. Either put stock air cleaner cover on or put stock cams back in.
My cam set has this noise too. You'll learn to just ignore it. Some bikes are worse than others for this noise as well as some cams make it worse.
[B]PV-Big Sucker-Rush Racing H-pipe-Big Louie's-Drago's 565 cams
Nightrain04 is offline
post #3 of 10 (permalink) Old 02-08-2016, 08:23 PM
cookie114's Avatar
same here
My 13 RG is all stock other than stage 1 kit. When I started running mine without the football cover the noise your talking about became loud as hell! Still trying to get use to it..... I've had other bikes with 88 and 96 ci running same setup and they didn't make the noise but everyone says it's normal so I'm trying to just get over it😥
cookie114 is offline
post #4 of 10 (permalink) Old 02-08-2016, 08:32 PM
jeff338wm's Avatar
Different cam setup, but quieted down significantly after replacing stock lifters with S$S premiums.
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #5 of 10 (permalink) Old 02-09-2016, 12:39 AM
What your are hearing is throttle body noise and a open air filter such as the heavy breather will increase the noise.
To begin with heavier valve spring won't fix your problem it will only make it worse. The throttle body is a megaphone that is a direct link to the intake valves and the noise caused by the closing of the valves seat hitting the head is transferred down and out the throttle body, a stronger valve spring will just increase the noise. Also pushrods are not the problem so take them out of the equation.
The other noise you hear is the throttle plate in the throttle body, the change of the throttle plate angle cause more or less air flow into the throttle body.
The increased cam lift will cause more noise out of the throttle body but with the .555 lift on the SE255 cams it shouldn't be too much of a issue.
The only thing you can do is use the stock air filter cover to cut down the noise.
post #6 of 10 (permalink) Old 02-09-2016, 06:33 AM
I'd suggest to install a set of S&S standard lifters, and load them to .140".
Should be VERY quiet at that point, as this methodology is what we use here when working with agressive cam profile noise.
Scott
Hillsidecycle.com is offline
post #7 of 10 (permalink) Old 02-10-2016, 05:21 PM Thread Starter
Thanks everyone with suggestions. Looks like will either get used to it or run stock air cleaner is alot quieter with stock sucks having a nice air cleaner just sitting. Least know changing some things wont help. Thanks again
Budd559 is offline
post #8 of 10 (permalink) Old 02-11-2016, 12:23 PM
Stick_FSMC's Avatar
I have the 103 with the Big Bore kit to increase it to a 110. I did that as soon as I got the bike.
That kit included the SE255 cams, SE110 heads, 58mm throttle body and I put the SE Heavy Breather on it at the same time, as well as V&H Power Duals w/Hi Output slipons.
I have had that same noise ever since I made the upgrades. 52K miles later it is still there, and no damage to the engine. It still runs just as strong as it did when the changes were first made.
You get used to it over time and there is no harm in it.
cookie114 likes this.
Stick
USAF 1980-84
Stick_FSMC is offline
post #9 of 10 (permalink) Old 02-11-2016, 10:58 PM Thread Starter
Thanks
Budd559 is offline
post #10 of 10 (permalink) Old 02-15-2016, 06:23 AM
They should not/no reason to sound like a clattering old Flathead.
Scott
video and popup overload h-donut Forum Help Desk (Post Forum Issues Here) 6 05-25-2015 10:18 AM
info overload wiggels Audio 9 07-15-2014 02:32 PM
Handlebar overload!!! Garemlin Controls & Handlebars 3 10-19-2012 06:40 AM
WTT: Arlen Ness Double Barrel Intake For Your Intake BadDadFLTR Wanted! (Buy or Trade) 2 08-27-2012 10:12 PM
05 valve noise deano1svs Troubleshooting for Road Glides 2 06-14-2011 09:12 PM
