Best Cam for 103 CI Engine - Road Glide Forums
 2Likes
  • 2 Post By 09Sharknose
post #1 of 10 (permalink) Old 02-10-2016, 08:54 AM Thread Starter
JohnnyIce's Avatar
Since I will have to be replacing my engine, I was going to put a 103 CI back in, but want to leave most of it stock. I have D&D Fat Cat 2 into 1 exhaust and the 58 mm intake, but want to put a cam in that will give me the most bang for my buck.
I am looking at the SE254E, SE255, or SE259E. Has anyone had experience with these on a stock 103?
Johnny Ice
2018 Road Glide Special. 114CI; Vance & Hines Crossover Headers; TPS Exhaust with Zombie Baffles;
JohnnyIce is offline
post #2 of 10 (permalink) Old 02-10-2016, 08:58 AM
09Sharknose's Avatar
News flash bro! With the D&D Fat Cat 2-1 and the 58mm TB you're a long way from stock!
I'm running the 58mm TB as a part of the stage IV and I have se259 cams and love the feel of the bike. You're going to get a 1000 answers from 1000 people that ride 1000 different ways. There is no right answer, it's just what feels good to you.
RGKen and Hawkman like this.
09Sharknose is offline
post #3 of 10 (permalink) Old 02-10-2016, 09:44 AM
Smarty's Avatar
If you are not going to do headwork, there aren't many cams that work any better than the Andrews 57H cams. Gary Andrews got this one right from the very get go. It also makes great power in the CVO 110's.
Smarty is offline
post #4 of 10 (permalink) Old 02-10-2016, 09:56 AM
Desertwndrr's Avatar
The 58mm intake is overkill for a 103". Throw in a set of Andrews 48's and ride the hell out of it. Much better cams than the three mentioned. Andrews 57's if you want to bump compression and work the heads a little bit.
FWIW I'm running 55mm throttle bodies on two different 124" builds and its plenty.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #5 of 10 (permalink) Old 02-10-2016, 10:09 AM
Smarty's Avatar
Per Gary Andrews, the new Rushmore bikes compression is perfect for the 57's. Anything more than 10:2-1 is to much. Actually for the amount of work even doing it yourself is not worth the gains from a compression gain. Maybe 3-5 in hp and it will be up in the high rpm range and the torque is virtually the same.
Smarty is offline
post #6 of 10 (permalink) Old 02-10-2016, 10:48 AM
sloride's Avatar
here is a 2013 RGC 103 with 2-1 Dragula, Zippers AC setup and TC-24 cams, tuned by Ed at the dyno difference
stock heads, compression and TB
attached is my dyno sheet
sloride is offline
post #7 of 10 (permalink) Old 02-10-2016, 10:57 AM Thread Starter
JohnnyIce's Avatar
Great numbers. I have the D&D Fat Cat Exhaust and 58 MM intake leftover from the engine failure. Looking to get a some pull with the new 103, but I know it will be nothing like my Stage IV with CNC MVC heads and what not.
Johnny Ice
post #8 of 10 (permalink) Old 02-10-2016, 11:04 AM
Khaotic's Avatar
No headwork planned still a big fan of Woods 222 otherwise 555 or 777 depending on how you ride.
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #9 of 10 (permalink) Old 02-10-2016, 11:13 AM
Smarty's Avatar
In my opinion and others, the 555 and the 777 underperform in the 103 configuration.
Smarty is offline
post #10 of 10 (permalink) Old 02-10-2016, 11:47 AM Thread Starter
JohnnyIce's Avatar
I had Woods TW777, which worked well, but that being said, this configuration will be more stock as far as the engine is concerned. Meaning the pistons, heads, and whatnot will be stock. I ride over 20K a year. To include back and forth from work, all year around. 1K rides within a day are not uncommon.
Johnny Ice
Tags
103 ci cams
2010 96 CI engine issues boardman74 *General Road Glide Discussions/Pictures 28 06-26-2017 10:08 PM
bone stock 2012 FLHX factory 103 ci strokerjlk Dyno Results 2 11-15-2013 11:29 PM
103 ci 1000mi service Rewash Tech Area 28 11-23-2012 07:42 PM
What do Ya'll think? 106"ci engine kit Wildman *General Road Glide Discussions/Pictures 22 03-30-2011 11:21 PM
2011 RG 103 Engine not only half a 103 Forger Road Glide Specific Discussions 21 12-13-2010 09:12 PM
