stage iv to stage V - Road Glide Forums
 2Likes
  • 2 Post By apgharleymech
post #1 of 10 (permalink) Old 02-10-2016, 08:27 PM Thread Starter
stage iv to stage V
is it worth it to dyno & add a s.e. tuner to a 2015 rgs with a stage lv kit ?????
nanook is offline
post #2 of 10 (permalink) Old 02-11-2016, 02:24 AM
apgharleymech's Avatar
In my opinion, if you're doing any real motor work, just flashing a download from HD isn't going to cut it. Rear motor work should be properly tuned... SE Pro tuner, Power Vision, TTS Mastertune... any flash tuner.... I've never been a fan of piggyback style tuners because I've seen them crap out and then you're shit up a creek. If you're going to put the money into it... do it right so you get the most, power, performance, and reliability...
madmat and Smarty like this.
Shiny and New '16 FLTRXS
Harley Davidson Arizona Proving Grounds
Mech Level 1
apgharleymech is offline
post #3 of 10 (permalink) Old 04-09-2016, 07:23 PM Thread Starter
Question
any other views , opinions???
nanook is offline
post #4 of 10 (permalink) Old 04-10-2016, 04:50 AM
neverdone's Avatar
Had a stage 4 installed on my 13. Love it.
neverdone is offline
post #5 of 10 (permalink) Old 04-10-2016, 08:19 AM
BigNorm's Avatar
Isn't PV piggyback? I have a PCV right now and wish I'd known about TTS before I did it. I want to go TTS as soon as I can afford it. It will be nice to run closed loop with tunability.
BigNorm is offline
post #6 of 10 (permalink) Old 04-10-2016, 11:05 AM
Desertwndrr's Avatar
If you have a stage IV already then shouldn't you already have a tuner? Maybe you should list out your current mods so that we know what you are working with.
Personal opinion....if you want to go any higher than a mild cam and street heads upgrade then you really should start thinking about addressing the bottom end.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #7 of 10 (permalink) Old 04-10-2016, 06:07 PM Thread Starter
Question desertwndrr?
what should i do to Bottom End?? i have dealer installed stage IV kit-v&h header pipes with cfr mufflers!!
nanook is offline
post #8 of 10 (permalink) Old 04-10-2016, 06:48 PM
BigNorm's Avatar
Replace the crank. The stock crank can shift if it's overbuilt. What exactly have you had done to your motor. Intake and pipes is generally stage one.
I'm going to quote Harley Jack here:
Originally Posted by HarleyJack View Post
Dont know about Harley stages but S&S is a good guideline
1 is intake and exhaust : high flow air cleaner and different exhaust
2 is 1 plus cams and push rods
3 is 2 plus big bore kits
4 is 3 plus ported heads and upgraded fuel system
like anything else you don't have to do all of the previous for one of the upgrades
So pretty much if you have a stage 4 setup you would have a tuner already. Go with whatever tuner your tuner wants to use and is comfortable with. My local dealer prefers SE Race tuner and TTS Mastertune.
BigNorm is offline
post #9 of 10 (permalink) Old 04-10-2016, 09:47 PM
It kind of depends on where you are HP and TQ wise and what you are trying to achieve. The stock crank is cast and has been known to be fine in a stock bike, but really show its limitations once you pump the power up. Stock HD cranks are also known to have runout tolerances that are higher than what most builders would consider acceptable. My bikes have had runouts from .004-.007, but the best was my springer softail that had a .029 runout.
Let's just say that you pump the power up with a Stage IV or Stage V kit. That is a pretty large chunk of change and if your crank can't handle it then you risk eating that motor up. It's kind of like the foundation on a house. Build the base strong to handle whatever you throw at it. I went with S&S cranks in my last two builds. Another option is to send yours out to be worked over.
post #10 of 10 (permalink) Old 04-11-2016, 09:17 AM Thread Starter
Cool
Thanks guys for info!
nanook is offline
Stage IV to a Stage V questions oc357 Engine Related 12 02-08-2016 09:20 AM
stage IV to stage V nanook Engine Related 0 11-01-2015 10:28 AM
Stage IV is out Stage II is back ironmark Engine Related 3 03-30-2014 05:42 PM
SE Stage IV 103 question abone Engine Related 114 09-01-2012 08:15 AM
2011 RG Stage IV SE Build gbourdon Engine Related 5 06-12-2011 05:03 PM
