How do I keep this engine from imploding? - Road Glide Forums
 67Likes
post #1 of 47 (permalink) Old 02-15-2016, 09:02 AM Thread Starter
twowheeladdict's Avatar
I am seeing these threads about engine issues at relatively low miles and am getting nervous about leaving the ultra reliable Japanese drive trains for this Road Glide.
The technician who showed me the bike after purchase said that I should never engine brake with this bike. He said that I should just use the brakes and pull in the clutch lever. This is totally foreign to how I have always ridden. I've never had to change brake pads on any bikes I have owned.
So, what are the rules of riding that will keep this engine going until I get bored with this bike?
twowheeladdict is offline
post #2 of 47 (permalink) Old 02-15-2016, 09:12 AM
lil chief's Avatar
What year of bike are you referring to?
The reason he is telling you not to engine brake is because it can beat the crank up, especially if doing it from a high rpm. It can cause the crank to twist. The earlier tc's (like around 2002) were a bit more beefy in that department.
I think we all engine brake to a certain extent, but it's easier for the tech to tell you not to do it, instead of him taking the time to explain why.
Lil Chief
Swomack likes this.
lil chief is offline
post #3 of 47 (permalink) Old 02-15-2016, 09:26 AM
tdkkart's Avatar
Just ride it.
For every 1 person that jumps on a forum with untold numbers of problems, there are hundreds of owners out there running
thousands of miles completely oblivious to all the problems that they are supposed to be having.
I'm on my 4th Twin cam engine ranging from 2001 to 2015. Besides all the other "problems" that I've never
had surface, I engine brake as hard and religiously as anyone and have yet to have an issue with a shifted crankshaft.
Big_gary, 08Zinc, RGKen and 6 others like this.
tdkkart is offline
post #4 of 47 (permalink) Old 02-15-2016, 09:31 AM
Smarty's Avatar
Originally Posted by tdkkart View Post
Just ride it.
Same here with the same outcome. I engine brake all the time coming to a stop. The main thing is to not slam on the brakes at any rpm with out pulling the clutch in and also not dropping the hammer from dead stop at higher rpm. It seems these are the main culprits of twisting a crank. I've redline shifted thru the gears on every bike I've owned with high horsepower motors and never had a problem. You hear stories, but not near as many happen as you would think. That's a big debate over on Harley Tech Talk. The consensus seems to be the same. Don't be an idiot and ride it like you stole it.
eddienelson likes this.
Smarty is offline
post #5 of 47 (permalink) Old 02-15-2016, 09:40 AM
twistr's Avatar
you claim you never changed brake pads on any bike you owned, so based on this info your road glide will stay in the garage a lot to worry about engine braking.
larry, Swomack and bigr545 like this.
Riding Life's Twisting Roads...
On a 2008 Dark Blue Pearl Road Glide
twistr is offline
post #6 of 47 (permalink) Old 02-15-2016, 09:41 AM
RGKen's Avatar
I've also had a tech tell me that engine breaking to save breaks just caused you to spend more money on tires because it wears out the tires quicker. He said he would rather spend less money on brakes than have to replace tires more frequently. I have to admit that I bit on this for a little while until I thought about why it might do this. Then I thought; doesn't braking put the same amount of friction on the tires against the road to slow the bike down? Hmmmmm...
Have yet to hear anyone else make that claim. I could buy the crank issue but not so sure about wearing out the tires faster unless I saw a conclusive test that proved it.
Smarty likes this.
2018 FLTRXS
RGKen is offline
post #7 of 47 (permalink) Old 02-15-2016, 10:11 AM
I dunno... I've always just ridden the damn thing and fixed it if something broke. I know if I'm riding like an idiot, something could break... I beat on my bike pretty hard, pretty regularly. Much more so than the average joe, and she takes it in stride and keeps right on going.
If something does break, I just consider it finding the weak point and try to find a way to make it better when I fix it... lol
Redfish-Joe, bigr545 and Ratdog33 like this.
padwell88 is offline
post #8 of 47 (permalink) Old 02-15-2016, 10:12 AM Thread Starter
I average 25,000 miles a year on two wheels. I have not exceeded 55,000 miles on any one bike though. I am always looking for the next bike. I generally part with a bike at around 40,000 miles, but some of the specific purpose bikes are hard to rack up the miles on.
I have never seen the need to race up to a red light and then hit the brakes, or race up to a curve and hit the brakes. I ride 'the pace'.
The Pace | Nick Ienatsch | Motorcyclist magazine
Jacksprat56 likes this.
post #9 of 47 (permalink) Old 02-15-2016, 10:17 AM Thread Starter
The tech told me that the engine could reverse direction or something like that. He also said engine braking wears the clutch plates.
post #10 of 47 (permalink) Old 02-15-2016, 10:27 AM
PGR
PGR's Avatar
Find a better tech.
Ron..........................
PGR is offline
How long do you keep your helmet? ChromeSpark Helmets 38 07-31-2018 09:38 AM
How do you keep sunglasses from bouncing with half helmet? James Helmets 30 07-21-2017 08:27 AM
Dealer said they had to do 1K service to keep factory warranty! transdude Fluids and Lubricants 34 06-29-2016 12:42 PM
How do court reporters keep a straight face? Wharf Rat General Off-Topic Discussions 2 08-05-2013 09:35 PM
Where do you keep your killintime *General Road Glide Discussions/Pictures 29 06-09-2013 03:34 PM
