RB Racing fuel injection - Road Glide Forums
 3Likes
post #1 of 18 (permalink) Old 02-21-2016, 02:23 PM Thread Starter
BigNorm's Avatar
Thanks to the Orca post earlier I got turned on to RSRs fuel injection. It is a complete system that replaces the stock system using actual manifold pressure as opposed to downloadable maps that Harley is so happy to provide us with (for a price). One of the things I was way let down about when I bought my 2011 FLTRU is that it didn't come with an actual system that automatically made changes for better flowing components. The RSR system claims it isn't a set and forget system and you will need to make adjustments for maximum tunability but they do stress this is something you can do yourself if you have some mechanical ability especially if you add a fuel/air guage. It is expensive and it is bulky (the ecu needs to be mounted in front so it doesn't overheat) but I also think this is something the moco should have provided stock. Our cars and trucks come with this versatility. Why don't our bikes?
BigNorm is offline
post #2 of 18 (permalink) Old 02-21-2016, 03:45 PM Thread Starter
BigNorm's Avatar
I've read some more and they recommend TTS Master tune if you have throttle by wire as most of us do but they recommend the fuel/air gauge still to make your own adjustments. lol. I like these guys. I know that time on the dyno is money well spent but it doesn't address all of the riding aspects. Since I am one of the "stupid people" (whoever writes for RB cracks me up) who runs a PCV. I may just go and buy the fuel air gauge until I can afford the TTS system. My Rhinehart pipes have the upper and lower O2 sensor locations so I may just run the old style sensors close to the exhaust ports to run the guage and the newer style to run the TTS when the time comes. I'm about to retire but I can see I'm going to need a new job just to pay for all the shit I learn about here and on HTT. Some of this stuff is just crazy and makes me want to sell my newer bike to buy an older bike so I can build a built evo motor with the RS tuner which is basically just old Honda tech that works.
BigNorm is offline
post #3 of 18 (permalink) Old 02-22-2016, 08:25 AM
"I know that time on the dyno is money well spent but it doesn't address all of the riding aspects."
Not true if the tuner is spending the required time. Good tuners cover all throttle positions set timing and afr in them.
I'm not sure if one changes exhaust, cams, and ports the heads on a car that it will auto tune to those changes.
rg113 is offline
post #4 of 18 (permalink) Old 02-22-2016, 09:44 AM Thread Starter
BigNorm's Avatar
I just know a manifold pressure system is a lot better than what the moco is giving us or a mass air flow system. The systems in our cars and trucks automatically change as needed. I know there are other things that need tinkering as you do more but right out of the box the bike shouldn't detonate.
BigNorm is offline
post #5 of 18 (permalink) Old 02-22-2016, 10:16 AM
Smarty's Avatar
Norm, you need to back up just one second. In the automotive industry we have extremely well water cooled engines with multiple fans etc. Also we are talking about 4 and 5 valve overhead cams, etc. You can do so much more with all of this helping with tuning. It allows you to run a very lean mixture and temps still stay low which still gives you good power and great fuel mileage. A lot more goes into it then what I"m explaining but you get the jest of it. With a harley engine, not are you not only dealing with a 45 degree engine with one crank journal, you are dealing with a pushrod geometry that is less than ideal. Now add two valve heads, air cooled ( I know we now have a water cooled exhaust jacket, minimal help) and limited space to improve on technology. Could Harley do something like the Dynojet Vision on the bike that lets you with the push of a button go from a cruising bike to more fuel and timing for sport or hi performance riding. Sure they could but in the scheme of things, I don't think that is necessary for the masses. When we do changes to our bikes, we need to think it thru and decide, are we gonna just do pipes, air cleaner and changes like that and be done with it? This is what most do. Then a simple flash or a piggy back tuner will suffice and give you years of satisfaction. Will it be 100% most power you can get out of that setup? No, but it will be close. Now for the rest of us that do cams, heads, throttle bodies, etc. Nothing beats a dyno tune and then that will give you many years of thrills.
To end on another note. If speak with any of the guys that are running some of the more sporty cars doing performance work, they are not just letting the cars computers do the adjustments. They are getting them dyno'd just like we do or doing an add on (piggy back tuning unit like I have on my Dodge Hemi 4x4 truck) to get more out of what they have. One size does not fit all. Good luck with your build and look forward to seeing your numbers when you are finished.
rg113 and Khaotic like this.
2016 RGS Black Quartz
Smarty is offline
post #6 of 18 (permalink) Old 02-22-2016, 05:10 PM Thread Starter
BigNorm's Avatar
It just looks a lot more tunable. I will get the TTS eventually. I like being able to get the most out of whatever I'm riding. I think step one will be that air/fuel gauge. I'm not knocking the value of a dynotune but I know it's only set for a single set of parameters. It can be 30 degrees here one day then 80 the next.
BigNorm is offline
post #7 of 18 (permalink) Old 02-22-2016, 09:35 PM
Smarty's Avatar
That's simply not true Norm. Once you dyno a bike, the values in all the boxes are as close to perfect as humanly and technically possible. Once that is achieved, the oxygen sensors adjust for altitude (amount of oxygen in the air) and keeps the a/f ratio where it's supposed to be. It doesn't matter if I ride up to Colorado in the mountains at 11,000 ft. or down by the ocean, my bike runs pretty close to the same in my opinion. Now if you change the cams or put a set of pipes that do not perform as well or perform better than the ones on with the dyno, you will need to have it dyno'd again. Good luck!
Smarty is offline
post #8 of 18 (permalink) Old 02-23-2016, 12:22 AM
JacktheBagger's Avatar
You are overthinking this Norm , I've dealt with RB in the far distant past , they are decent guys , they have an in your face attitude , and they know what they are doing , they build LSR motors and Bonneville has been their passion for years , your money but I hate to see you throw it away on stuff you dont need .. AFR gauge isn't much good unless you can adjust on the fly , their FI system is probably ideal for Bonneville , where they can tweak it for everything it's worth , doubt there is much it can do , that TTS or any other tuner cant do ..
2011 Ultra
JacktheBagger is offline
post #9 of 18 (permalink) Old 02-23-2016, 06:20 AM
BlownBagger's Avatar
+1 I couldn't agree with you more
_
BlownBagger is offline
post #10 of 18 (permalink) Old 02-23-2016, 06:21 AM
Big norm:
There are also other ways to tune,if you were to look up Mr.Bruce Bean @ Big Boyz head porting he has a good article on his Web sight on the way he tunes (exaust gas analysis) good luck.
dozer23 is offline
RB racing experiences jj8823 Engine Related 14 07-07-2014 06:28 PM
RB Racing caboverbob Intake and Exhaust 10 07-11-2013 11:13 AM
RB Racing Black Hole exhaust on Ebay SMSgt B Intake and Exhaust 0 04-06-2013 11:22 AM
RB Racing Intercooled Harley Turbos DreamRider Engine Related 20 01-12-2012 05:24 PM
RB Racing OKroadglide Intake and Exhaust 7 07-16-2010 09:42 PM
