disturbing piston pictures - Road Glide Forums
 5Likes
post #1 of 18 (permalink) Old 02-23-2016, 01:05 PM Thread Starter
unbalanced's Avatar
Some scary pictures
-Unbalanced
He who laughs last thinks slowest.
unbalanced is offline
post #2 of 18 (permalink) Old 02-23-2016, 01:21 PM
BigNorm's Avatar
Ouch! What size valves/cam did that?
BigNorm is offline
post #3 of 18 (permalink) Old 02-23-2016, 01:33 PM
Sparky0426's Avatar
Was anything odd going on before that? Sorry to hear about your trouble.
2018 Ultra, Twisted Cherry
Sparky0426 is offline
post #4 of 18 (permalink) Old 02-23-2016, 02:11 PM
VikingRider's Avatar
Whoa – happened after a rebuild or what? Btw what make & type engine is it?
@ BigNorm - was thinking the same thing about the cams...
FLTRSEI2
VikingRider is offline
post #5 of 18 (permalink) Old 02-23-2016, 04:20 PM
Wow! what do the heads look like?
303RG is offline
post #6 of 18 (permalink) Old 02-23-2016, 06:02 PM
Smarty's Avatar
Originally Posted by unbalanced View Post
Some scary pictures
I'm thinking one of two things. You were changing out a cam and put in adjustable pushrods and didn't get the cams on the base circle with piston at top dead center when adjusting or cams put in not lining up the timing marks. I'm I close? By the way, that sucks big time. New valves, valve guides, and seals on the valves that hit.
2016 RGS Black Quartz
Smarty is offline
post #7 of 18 (permalink) Old 02-23-2016, 06:51 PM
tdkkart's Avatar
Back in the 88 to 95" conversion days this used to be a fairly common picture. There were some pistons out there, even some SE pistons, that had valve reliefs that weren't quite right. Different cams, bigger valves, milled heads and thin head gaskets quite often stacked up to valves touching pistons here and there.
Not a HUGE deal as long as you caught it quick enough before it finally broke the head off the valve. A lot of bikes ran for a long time that way.
midwaywfo likes this.
tdkkart is offline
post #8 of 18 (permalink) Old 02-23-2016, 07:29 PM
BigNorm's Avatar
I can't imagine how loud the clanging had to be.
BigNorm is offline
post #9 of 18 (permalink) Old 02-23-2016, 07:30 PM
Ohiobellboy's Avatar
Someone bring that in to you for a build or a repair?
A.K.A OBB
Ohiobellboy is offline
post #10 of 18 (permalink) Old 02-23-2016, 07:48 PM
tdkkart's Avatar
Actually, a little divit like that barely makes an extra click over the regular valvetrain and exhaust noise, and once it's hammered the divit it doesn't make noise any more. The only real reason it shows up is if it bends the valve, which it may not, and somebody took it in because "somethin' ain't right".
Valves are surprisingly flexible and don't always break.
tdkkart is offline
Disturbing site palmpalm *General Road Glide Discussions/Pictures 92 02-05-2013 09:37 PM
Brake piston reseating? StephenRG Troubleshooting for Road Glides 1 08-05-2012 06:20 PM
FS Hawg Halters 4 Piston Calipers and LRB rotors hd4cruzin Classifieds Archive (3 months old+) 2 03-14-2012 01:46 AM
six piston single side front brake install scorpiohd Do-IT-Yourself 15 03-02-2012 09:34 AM
96" high comp piston swap?? slowglide2989 *General Road Glide Discussions/Pictures 5 09-02-2010 07:10 PM
