Andrews 26 to Andrews 57 - Road Glide Forums
post #1 of 3 (permalink) Old 02-29-2016, 01:23 AM Thread Starter
I am currently running Andrews 26 cams. They were in the bike when I purchased it. It is supposed to have ported heads already. The actual compression ratio is unknown. I feel the bike runs well but the only bike I've had to compare it to is a stock TC88 Dyna that I owned before the RoadGlide.
I'm in need of replacing tensioners due to wear and beyond wear. since I will have everything apart I'm exploring my options at this time.
I've seen several folks recommending the 57s over the 26s.
Of course there's the thirst for more power. I like to ride spiritedly and will be 2 up 30-40% of the time possibly.
Is there enough difference to justify the cost? Also these say hi lift, will this be compatible with otherwise stock springs/valves?
Thoughts?
1999 Road Glide, 95" Andrews 37, Power Commander 3, D&D Fatcat 2-1, Big Sucker
Bill-99RG is offline
post #2 of 3 (permalink) Old 02-29-2016, 05:37 AM
mocotom's Avatar
If the bike you are referring to is the 1999 in your signature and the heads are using stock springs, then the answer is NO. The springs will not work (coil bind) with the lift of the Andrews 57.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 3 (permalink) Old 02-29-2016, 06:28 AM Thread Starter
Awesome. Thanks.
I was wondering at which amount of lift it became an issue. I have no real idea as to my true springs but I'm assuming stock to err on the side of safety. This is good as it saves some coin I really didn't need to spend anyway.
Rule #57: Do Not Ride Behind Morons Motorcycle.com *General Road Glide Discussions/Pictures 6 07-02-2016 03:20 PM
PV/ Andrews 57/ H Pipe/ 103 Wmoor004 Map Section 3 02-13-2015 06:39 PM
09 106" with head work andrews 57 and dragula exhaust DragoBikeWorks Dyno Results 10 09-14-2012 09:29 AM
Andrews 26 vs. SE 255 SLOglide Engine Related 5 03-15-2011 06:54 PM
