are my tensioners worn? - Road Glide Forums
 5Likes
post #1 of 19 (permalink) Old 03-06-2016, 06:31 PM Thread Starter
i'm sorry this is my first post, I've been lurking for a long time and then signed up.
I've searched and searched and haven't come up with an exact answer or picture looking like mine and with the week I'm having with family member dying, dads car breaking the day he got it, my bicycle breaking, id rather have a second opinion on this !!!
if i replace them I'm going to replace them with normal spring tensioner shoes. I've spent a lot of money on this bike since i bought it in november and can't swing the extra cash this season for upgraded.
its a 2004 with 34k miles that was 100% stock until i bought it.
Dante is offline
post #2 of 19 (permalink) Old 03-06-2016, 06:57 PM
mocotom's Avatar
The new spring style tensioners have a teflon wear pad that lasts much better than that bake-o-lite pad you now have or the pads can be bought separately on ebay and you reuse your existing spring tensioner assembly
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 19 (permalink) Old 03-06-2016, 07:08 PM Thread Starter
Yeah I've seen some good upgrades.
Do mine look worn though?
Dante is offline
post #4 of 19 (permalink) Old 03-06-2016, 07:11 PM
Hullhorr's Avatar
That pad needs to be replaced
Caveman likes this.
2009 FLTR MOP
Hullhorr is offline
post #5 of 19 (permalink) Old 03-06-2016, 07:22 PM
mocotom's Avatar
Yes. They need replaced!
Caveman likes this.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 19 (permalink) Old 03-06-2016, 07:45 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
Replace, However...
They should be replaced, but for 34k they look pretty good.
RGKen likes this.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #7 of 19 (permalink) Old 03-06-2016, 08:05 PM Thread Starter
i didn't realize the headache it is to replace the tensioners. how bad those look? RI riding seasons don't last that long. think they've got another 5,000 in them and i can do cams and everything next winter?
Dante is offline
post #8 of 19 (permalink) Old 03-06-2016, 08:07 PM Thread Starter
i didn't realize what a headache it is to replace them. i didn't even think about the cams being pulled and stuff.
how bad are those? they have another 5,000 in them you think? id rather replace them next winter and save up for some cams and stuff.
Dante is offline
post #9 of 19 (permalink) Old 03-06-2016, 08:39 PM
Smarty's Avatar
Usually the back cam pads are the ones that wear faster. I would say, you will be surprised when you pull the cam plate and see it.
2016 RGS Black Quartz
Smarty is offline
post #10 of 19 (permalink) Old 03-06-2016, 09:11 PM
ERod62's Avatar
Get the new Screaming Eagle upgrade with oil pump system, they use hydraulic tensioner better shoes material and chain less wear on tensioners. HD dealers use to have the OE and upgrade system setup on a display with a hand crank way less friction on the upgrade kit.
I did the upgrade on my 04 RK at 35 k miles no issues after.
ERod62 is offline
Worn alternator rotor causing loose compensator Sideways Troubleshooting for Road Glides 1 08-22-2016 03:54 PM
Rear brakes worn out 14k. Hot rotor seahoch Troubleshooting for Road Glides 11 04-06-2014 01:30 PM
Once Worn Interstate Leather Jacket k9shag Miscellaneous for Sale 5 10-04-2013 08:13 PM
Brand new never worn Ladies Tourmaster denim jacket RaceBizz Miscellaneous for Sale 1 01-09-2013 06:53 PM
Brand New Never Worn Ladies Tourmaster Transition 2 jacket RaceBizz Miscellaneous for Sale 0 12-18-2012 11:45 PM
