Crusher TC-24D cams - Road Glide Forums
 3Likes
post #1 of 31 (permalink) Old 03-10-2016, 12:13 AM Thread Starter
r_einan's Avatar
Crusher TC-24D cams
Anyone try these yet? The few dyno sheets I've found look pretty solid. Seems like a promising choice, somewhere between the woods 222 and 555 with better legs than the Andrews 57.
r_einan is offline
post #2 of 31 (permalink) Old 03-10-2016, 07:16 AM
Set at 10.4 cr they work well.
We keep those on the shelf here.
Scott
Hillsidecycle.com is offline
post #3 of 31 (permalink) Old 03-10-2016, 08:56 AM
sloride's Avatar
I have ran them in both the 103 and 110 with stock compression and they work very well.
here is the thread of the 110 ci
https://www.roadglide.org/54-dyno-res...ew-h-pipe.html
the thread for the 103 is here
https://www.roadglide.org/26-engine-r...ggestions.html
sloride is offline
post #4 of 31 (permalink) Old 03-10-2016, 11:11 AM
Ok I'm also looking to do cams in 15 rgs.I mostly ride back roads often hot dogging it. The kury tc 24 cam is 400.00 and the andrews 57 is 240.00 I will be decking heads and larger intake valve,lifters and rods is it worth it too go with the tc24? sorry to hijack your thread.maybe we can both get some useful info.
dozer23 is offline
post #5 of 31 (permalink) Old 03-10-2016, 12:48 PM Thread Starter
r_einan's Avatar
No worries, I am gathering info to formulate my plans for next winter. The TC-24d is on my list of cams to gather info about. I'm not looking to have the heads off or raise my compression. I regularly ride in summer temps of 100-105 and don't want the potential issues of higher compression on an air cooled engine.
Also on the list of possible can choices is the Genesis 577 from GMR, the Dragos 580 from Frank, and maybe the Andrews 57H. Cost of the cams isn't really a concern for me, I'd rather have the best running machine for my needs and a hindered or two doesn't mean much in the scheme of things. Another concern for me is the lack of competent tuners in my area. I need to be able to get a solid base map and auto tune with the PV to stay on the road until I can source a proper tune. SE Washington isn't flush with good dyno guys.
The thing for me is that I use the whole rpm range, I regularly run her up to 5k and also ride down in the 2-3k range in town. I don't drive a cage unless I absolutely have to. I want a cam that isn't a huge trade off in either area.
r_einan is offline
post #6 of 31 (permalink) Old 03-10-2016, 02:10 PM
sloride's Avatar
Guys,
The TC-24 will not make as much low end TQ as the GMR 577 or the Dragos 580. It will make slightly better mid-range and better top end than those cams in a stock motor.
IMO for the riding styles your talking about I think the Dragos 580 has a broader and flatter TQ curve and would have better throttle response than the TC-24 or the GMR 577. I have ridden all 3 cams in stock 103 baggers
The bonus with the Dragos cams is that Frank will build and send you a Power Vision tune for your bike with his cams and your exhaust that will work just fine. nothing is as good as a dyno tune...but Frank can get close.
dozer23 likes this.
sloride is offline
post #7 of 31 (permalink) Old 03-10-2016, 03:04 PM Thread Starter
r_einan's Avatar
You have ridden stock 103 baggers with all three? Could you compare and contrast the overall mannerisms of each? Valve train noise and heat production are also concerns from me, as well as the ability to handle less than stellar gas in the parts I ride. Sounds like you are the guy to talk to on this one.
r_einan is offline
post #8 of 31 (permalink) Old 03-10-2016, 04:25 PM
sloride's Avatar
My 2013 RGC "The Reaper" with Dragos Dragula exhaust and TC-24 cams with bobby Woods lifters and HD SE adjustable push rods. An absolute beast from 3000 RPM up (would smoke a stock CVO in a all out race). Would lug a little while riding two up in the lower RPM ranges. A little quieter than stock HD but not by a lot. Tuned by Ed at the Dyno Difference
My Nephew's 2012 SG "Beast" with D&D 2-1 exhaust Dragos 580 cams, S&S lifters and push rods. Great roll on the throttle response and did not lug at all riding two up. (It would not out run the Reaper in a all out race but it was not that far back there) quite a bit quieter than a stock HD. Tuned by Ed at the Dyno Difference
My buddy Mike's 2013 RK with Vance and Hines Power duals, GMR 577 cams and lifter and push rods. This cam did not seem to have the low end grunt of the Dragos 580 or quite the upper end TQ Pull of the TC-24's. But saying that, this was still a really fun bike to ride. I really don't remember about the noise. Tuned by Steve at GMR
I don't think you can go wrong with any of these cams.
The TC-24 will really come alive with more compression and head work. If you plan on doing this, that's the direction I would go.
If your not going to any other mods, I would go with the Dragos 580 or GMR 577
Taccone likes this.
sloride is offline
post #9 of 31 (permalink) Old 03-10-2016, 04:28 PM
R_einan:this thread is going to get good!would be nice if Frank could give his opinion,I have seen in the past that he has worked with all these cams.
dozer23 is offline
post #10 of 31 (permalink) Old 03-10-2016, 05:32 PM Thread Starter
r_einan's Avatar
From your impressions, I am inclined to agree with your opinion. It seems like the 580 is better suited to my riding and needs than the 24D. Thank you for taking the time to share your experience, it is very helpful.
I run fuelmoto 2-1-2 stainless head pipes with 3.5" bassanis out back. I wonder how the different pipe (compared to a 2-1) would effect the down low characteristics on these cams. Also, I'm on a '15 RG, and IIRC the compression is slightly higher than the '13 and down.
r_einan is offline
Putting the TC-24 cams in Bevo sloride Engine Related 9 07-23-2014 06:39 AM
Kuryakyn Crusher 2-1-2 tj316 Intake and Exhaust 0 07-30-2011 12:21 PM
Cams for a TC 103 Gonekat Engine Related 3 02-20-2011 08:04 PM
