Engine Knocking - Road Glide Forums
 13Likes
post #1 of 25 (permalink) Old 03-12-2016, 08:55 AM Thread Starter
bike51's Avatar
Engine Knocking
When I start up (cold), engine has a loud knocking. I mean loud! After about 2 mins it starts to quiet down. I can't let it idle too much longer (neighborhood). After riding about 2-3 miles, it stops. Oil level is normal, either hot or cold checking.
Should I be concerned????
bike51 is offline
post #2 of 25 (permalink) Old 03-12-2016, 08:58 AM
Probably a lifter.
rg113 is offline
post #3 of 25 (permalink) Old 03-12-2016, 09:27 AM
Desertwndrr's Avatar
Yup. Sounds like a lifter. S&S Lifters are very good replacements or if on a budget you can use the Comp Cams 850 lifters.
bike51 likes this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #4 of 25 (permalink) Old 03-12-2016, 09:32 AM
Spazz's Avatar
Food for thought here.... I had a similar issue on a 2013 Breakout.
Mine only did EXACTLY what you are describing when it sat for 2-3 days and was COLD out... 30's to 40's. When I road it every day, it would only clunk for about 15-30 seconds.... not 2+ minutes. It did go on for 2-3 minutes if I left it for 2-3 days... FYI
I had brought it in for this and described it.... I told them to leave it sit in an uncontrolled environment ( not temp controlled ) for 2-3 days.
they finally found the issue.... the pressure relief valve in the cam plate was sticking... not allowing proper oil PSI. They replaced the cam plate and PRV under warranty... never had an issue after that.
bike51 likes this.
RENO BAGGER AUDIO
Spazz is offline
post #5 of 25 (permalink) Old 03-12-2016, 09:32 AM
! rock103 !'s Avatar
I get the same knocking sound for about the same duration. It's making it real hard to wait until the warranty expires for me to change out lifters, adjustable pushrods and cams...
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #6 of 25 (permalink) Old 03-12-2016, 10:05 AM Thread Starter
bike51's Avatar
Knocking
Thanks for the feed back. Its a 2015, only 2000 miles.
I'll go to HD and hopefully get some satisfaction.
bike51 is offline
post #7 of 25 (permalink) Old 03-12-2016, 10:09 AM
Why would you wait?? Even if you didn't upgrade you should get the problem looked at and R&R if needed. The lifters are a warranty item and if they are not addressed soon you can have more damage to the engine.
The first time the lifters or cams are serviced the adjustable pushrods should be installed just because it will make future lifter or cam chest R&R easier and less costly.
93-331-29psi and RGKen like this.
post #8 of 25 (permalink) Old 03-12-2016, 10:14 AM
True...may say F it and just do it. Otherwise I will run it by the dealer, but I am sure they will say "its normal" or "nuthin wrong with it"...So I am thinking they won't change them under warranty. But doesn't hurt to ask!
cookie114 likes this.
post #9 of 25 (permalink) Old 03-12-2016, 10:16 AM
Which means I will have to leave the bike there overnight I am sure.
post #10 of 25 (permalink) Old 03-12-2016, 10:23 AM
Plan on doing Rockouts too when I did it.
Knocking sound emptyking Engine Related 8 07-26-2016 10:18 PM
Engine Cold, bad knocking noise at idle... Scootin Engine Related 18 06-02-2016 09:14 AM
103 idle knocking HDMARK Troubleshooting for Road Glides 13 06-29-2012 03:19 PM
Ticking and knocking ransom1567 Troubleshooting for Road Glides 0 05-28-2012 11:25 AM
knocking or metallic sound big papa *General Road Glide Discussions/Pictures 1 10-18-2011 07:54 AM
