HD Oil Filter stuck - Road Glide Forums
 18Likes
post #1 of 26 (permalink) Old 03-13-2016, 08:38 PM Thread Starter
1st Sgt's Avatar
HD Oil Filter stuck
Went to replace the oil filter (chrome) tonight after the top end rebuild by Blackjack HD here in Florence and the SOB won't budge one bit. I have two of the HD wrenches, tried both and they both slip without budging the filter. Engine was at operating temperature when I tried this. Before sticking a screwdriver into the filter - what other suggestions are there out there???
1st Sgt is offline
post #2 of 26 (permalink) Old 03-13-2016, 08:47 PM
tdkkart's Avatar
Take it back to the dumbf&*k that put it on that tight.
When he gets it off, take it from him and put it in his front pants pocket open side down.
tdkkart is offline
post #3 of 26 (permalink) Old 03-13-2016, 08:47 PM
stab the sum bitch with a big screwdriver.
fwbkent is offline
post #4 of 26 (permalink) Old 03-13-2016, 08:52 PM Thread Starter
1st Sgt's Avatar
Are you talking about the filter or the guy that put it on????
reds4 and Shadow1 like this.
1st Sgt is offline
post #5 of 26 (permalink) Old 03-13-2016, 08:55 PM
both
dozer23 likes this.
fwbkent is offline
post #6 of 26 (permalink) Old 03-13-2016, 09:47 PM
Howardsternspenis's Avatar
Angry Been there!
The first time I changed my own oil I found the "tech" at the dealer that did my 1K service had not lubed the rubber seal on the oil filter and he over tightened it.
Took me forever to get the damn thing off.
I didn't skewer it with a screwdriver but I did get primitive with a big pair of channel lock pliers and finally got it off.
ALWAYS PUT A THIN COAT OF OIL ON THE RUBBER O RING ON THE OIL FILTER BEFORE YOU TIGHTEN IT DOWN, HAND TIGHT.
Good luck!
HSP
Howardsternspenis is offline
post #7 of 26 (permalink) Old 03-13-2016, 09:48 PM
Squidlow's Avatar
I second stab both those SOBs with a large screwdriver. Then switch to a K&N oil filter because they have a nut welded on so you can use a ratchet with a regular socket so no clearance issues.
z2thdr and snarley53 like this.
Squidlow is offline
post #8 of 26 (permalink) Old 03-13-2016, 10:11 PM
SurlyBoy's Avatar
FYI, The welded on nut on K&N filters doesn't always work. It's just formed sheet metal and if the filter is really stuck on there isn't enough for a socket to get a decent grip.
You can't always blame the tech. I do my own maintenance and have managed to get filters jammed on a couple of times. I'm pretty careful about not over tightening them.
Also, I'd try a lot of things before resorting to jamming a screwdriver through it. The filter is just thin metal. The screwdriver can tear through it without budging it and then you'll be left with nothing to get a grip on if it doesn't work. I picked up a filter removal tool at advanced auto that has three finger that tighten down the harder you turn it. The fingers fit over the end but still clear the cylinder base. You can find them at Wally mart or wherever
snarley53 and eddienelson like this.
SurlyBoy is offline
post #9 of 26 (permalink) Old 03-13-2016, 10:51 PM
Smarty's Avatar
Get the filter strap that has a socket on it. Harbor Freight
2016 RGS Black Quartz
Smarty is offline
post #10 of 26 (permalink) Old 03-13-2016, 11:08 PM
bucketlisthd's Avatar
I was able to sneak a HF strap wrench in from the front of the bike. Works.
RGKen likes this.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
K&N Filter vs.HD Oil Filter RRHartzler Fluids and Lubricants 49 10-22-2016 08:00 PM
Ignition switch Stuck & i mean stuck.... maddmoe Troubleshooting for Road Glides 11 07-08-2016 06:22 AM
oil smell & oil in air filter fat boy ultra Troubleshooting for Road Glides 6 04-11-2013 11:04 AM
Stuck K&N oil filter Sethjamto Engine Related 25 01-27-2013 04:22 PM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 12:38 PM
