pros of adding high performance lifters - Road Glide Forums
 5Likes
post #1 of 17 (permalink) Old 03-16-2016, 11:18 AM Thread Starter
cookie114's Avatar
Been reading alot about ppl swapping out stock HD lifters for S&S /high performance lifters in these newer engines. Jut wondering what the pros are of doing this? My bike is stock other than stage 1 kit and I THINK it may be my lifters that are a little noisier than the past bikes I've had. Thinking of doing a swap but like to know if it's worth it
2013 FLTRX, stage 1 w/vance and hine power duals and rinehart slipons, TTS mastertune and some other odds and ins. Long ways to go
cookie114 is offline
post #2 of 17 (permalink) Old 03-16-2016, 11:43 AM
Don't fix what's not broken. Wait until you hear the lifters fail which is usually a rattle sound when starting the bike after it was sitting for a long time.
Nevadasun likes this.
post #3 of 17 (permalink) Old 03-16-2016, 12:04 PM Thread Starter
cookie114's Avatar
On cold mornings I'm getting a rattl on start up that last a few seconds
post #4 of 17 (permalink) Old 03-16-2016, 12:35 PM
It's the lousy "C" lifters that came in your bike. My 2015 RG made the same noise as yours occasionally at around 5000 miles, and every morning by 9000 miles. Changed to S&S standard lifters (my bike is stock also) and SE adjustable push rods, no start up rattle, and super quiet, all temps.
cookie114 likes this.
rg113 is offline
post #5 of 17 (permalink) Old 03-16-2016, 12:38 PM
If it only last a few seconds and goes away then it isn't that bad, the lifters just bleed off a little and need to be pumped up some which happens to brand new lifters.
If the rattle gets longer and louder then it would be time to address the problem, it is your decision when to replace the lifters since it is your bike and you can hear it better than anyone .
post #6 of 17 (permalink) Old 03-16-2016, 01:09 PM
FrankieB's Avatar
On your bike I wouldn't waste the money on the S&S premiums, if you are dead set on s&s then just use their standard lifter. I would just use a set of comp cam 850-1's. You can usually find them less then $20 a lifter.
kouack and cookie114 like this.
06 RK
11 RGU
FrankieB is offline
post #7 of 17 (permalink) Old 03-16-2016, 01:34 PM Thread Starter
cookie114's Avatar
Couple dumb questions for ya.
1. What does changing out the push rods do?
2. Changing out the lifters / push rods doesn't affect tune does it?
post #8 of 17 (permalink) Old 03-16-2016, 01:36 PM
tdkkart's Avatar
I'll 2nd the Comp Cams 850-1 lifters, used them a couple times, always run quiet.
COMP Cams High Energy Hydraulic Roller Lifters 850-1 - Free Shipping on Orders Over $99 at Summit Racing
tdkkart is offline
post #9 of 17 (permalink) Old 03-16-2016, 01:44 PM Thread Starter
cookie114's Avatar
I'll check that out. I also shouldn't have put High performance lifters on the post. The standard S&S I what I'm looking at but I'm open to others.
post #10 of 17 (permalink) Old 03-16-2016, 02:19 PM
tdkkart's Avatar
The 850-1 Comp Cams lifters are the very same lifters that Comp Cams sells under the V-thunder
name. Last summer I needed a set "today" so I went to J&Ps to pick some up. The V-Thunder lifters
were double bagged, with the inner bag being the Comp Cams 850-1 bag.
I've used Comp Cams stuff in cars and trucks for many many years and never had a single failure, I
have no qualms with using their stuff in my bike.
tdkkart is offline
Woods performance lifters less than 2k miles $150.00 pat123 Parts for Sale 0 08-17-2014 09:07 AM
Gaterman 1023 performance lifters J.I.M.S. Classifieds Archive (3 months old+) 0 06-23-2012 09:14 PM
Gaterman 1023 Performance lifters J.I.M.S. Sold 0 06-03-2012 04:16 PM
