.030 Head Gaskets in the HO 103's - Road Glide Forums
 2Likes
post #1 of 16 (permalink) Old 03-17-2016, 12:18 PM Thread Starter
How much compression gain is realized from using the .030 head gaskets in a HO 103? The stock compression is supposed to be 9.7 to 1. The old compression ratio was 9.5 to 1 and most results show a .2 to .3 compression ratio increase. I haven't found any specifics for the HO 103's. I'm in Denver so all of the compression numbers are a little skewed to start with.
303RG is offline
post #2 of 16 (permalink) Old 03-18-2016, 07:49 AM
Your figures are probably pretty close, .25 is the norm. The real value of a .030" HG is the tighter squish = better burn.
rg113 is offline
post #3 of 16 (permalink) Old 03-18-2016, 09:55 AM
Smarty's Avatar
When you pull your heads, check how for down in the hole each piston is. Put piston at top dead center and take a straight edge across the top of each cylinder and take a feeler gauge and measure the distance between the piston and the straight edge. Each side could be a little different. Usually not much though.This is called measuring the deck height. The volume of how far down in the hole the pistons are and the volume of the combustion chamber of the heads will give you how many cc's your total combustion chamber is. This now can be figured into what size head gasket can be used to get the compression ratio you desire. I will look for the conversion of cc's to compression ratios and post up again. Most shoot for around 83 t0 85 cc's.
Here you go: http://www.bigboyzheadporting.com/TwinCamComp.htm
2016 RGS Black Quartz
Smarty is offline
post #4 of 16 (permalink) Old 03-18-2016, 10:03 AM
Smarty's Avatar
You can see if you play with the numbers on Big Boyz site things change quickly. Such as if you heads cc at 83 instead of 85 it increases compression ratio very quickly. Also when you measure deck height and enter these numbers the effects are pretty dramatic.
Smarty is offline
post #5 of 16 (permalink) Old 03-18-2016, 11:29 AM
The reason the 103 HO engine has more compression than the earlier 103 engine is that HD used a different cam. The cam will change the compression ratio more than a head gasket will.
The increase of compression with a .030 head gasket isn't worth it IMO why tear down the heads and do all that work for such little gain in performance. Now if you had to tear down the top end to do a R&R or you were putting in a big bore kit then it makes sense to use the .030 head gasket. JMO
post #6 of 16 (permalink) Old 03-18-2016, 01:32 PM Thread Starter
Thanks for the responses. I'm not ripping into the motor. I did it last year. My buddy and I were discussing the best build for him. He'll probably do the same thing I did. Mild port/polish, valve springs, cam and pushrods. The question is really will the thinner head gasket help his performance? I say it can't hurt.
303RG is offline
post #7 of 16 (permalink) Old 03-18-2016, 03:46 PM
Darreldanger's Avatar
The cam has absolutely zero effect on compression!!!
Darreldanger is offline
post #8 of 16 (permalink) Old 03-18-2016, 06:35 PM
Smarty's Avatar
Ironmark, I want to hear the explanation as to why a cam would change the compression of of a build. I understand the term corrected compression but as for our compression which is the determined by the cc's of the combustion chamber which is the size of bowl in the heads and the deck height.
Smarty is offline
post #9 of 16 (permalink) Old 03-18-2016, 06:37 PM
Smarty's Avatar
He may have it confused with cranking compression which is determined by the cam lobe and overlap.
Smarty is offline
post #10 of 16 (permalink) Old 03-18-2016, 06:51 PM
tdkkart's Avatar
Yes......
Camshaft does not affect static compression, but will affect dynamic(cranking)
Smarty likes this.
tdkkart is offline
2016 RG tman 600sm cams/.030 head gasket 2016RGproject Dyno Results 10 02-16-2016 09:43 AM
2014 HO Cam into a earlier 103??? CSM-H Engine Related 7 10-06-2014 03:29 PM
SE 103 HO KIT Throttle Body Noise RCKYMTNRDR Engine Related 14 01-02-2013 04:50 PM
