Pushrods... - Road Glide Forums
  • 1 Post By ironmark
post #1 of 6 (permalink) Old 03-18-2016, 12:57 PM Thread Starter
GusEmery's Avatar
Send a message via Skype™ to GusEmery
Pushrods...
I'm swapping out my stock cam in my '09 RG to an Andrews 48H. I'm wondering if I need to switch out my pushrods to adjustable or not. I've done cam work in the past, and used the old "bolt cutter" routine, so I'm not worried about that or cost. Just wondering if I crack the rocker boxes and pull the old ones out, if it's ok to reuse them or not..
-G
GusEmery is offline
post #2 of 6 (permalink) Old 03-18-2016, 01:18 PM
! rock103 !'s Avatar
If you don't remove them out the top by removing rocker boxes, then yeah you'd need new adjustable pushrods. Not that you have to change the lifters, you'd be wise to upgrade to a better lifter while in there. Otherwise you can just leave them in when swapping the cam and pushrods. Just need a couple of wire clips from those big paper clips.
https://youtu.be/n5KvamRqCis
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #3 of 6 (permalink) Old 03-18-2016, 01:54 PM Thread Starter
GusEmery's Avatar
Great.. Yes, I've done a couple of swaps with adjustable pushrods.. Just don't know if it's worth the cost for a few minutes of pulling the rocker boxes... The reason I'm leaning that way is that the tank is already off while I"m running wiring, or it'd be a moot point! I'd totally cut and replace...
Thanks however on the lifter suggestion.. I read in another thread about lifters.. I'll have to check and see.. If the other price was correct.. $80 for a set, it seems stupid not to swap them at the same time!
-G
GusEmery is offline
post #4 of 6 (permalink) Old 03-18-2016, 06:47 PM
Smarty's Avatar
-G
About as quick to pull the rocker boxes and rocker arms. Yes, stock rods work on a 48 and if you haven't changed out the inner cam bearings, do it now with torrington and put new lifters in too. Many happy miles after that.
2016 RGS Black Quartz
Smarty is offline
post #5 of 6 (permalink) Old 03-20-2016, 09:33 AM
As long as the base circle on the cam your installing is the same as the stock cam you can use the OE pushrods. I've found I can get less noise with adjustable, unless the lobes on the cam are very steep.
rg113 is offline
post #6 of 6 (permalink) Old 03-20-2016, 11:04 AM
IMO the adjustables PR are a must. It just makes future cam chest work or lifter R&R a lot easier. Also you can put the correct load on the lifters when you use adjustable PR. If the cam lift is more than the stock cam is then the lifters can be overloaded which can cause problems.
rg113 likes this.
S&S Cycle Quickee Pushrods SMOKENJOE Engine Related 0 05-02-2013 12:35 PM
Pushrods ksarauer Engine Related 15 12-04-2012 01:25 PM
3 Hours for Adjustable Pushrods? OldNerdGuy Engine Related 8 06-14-2012 07:01 AM
Adjustable Pushrods 17997-99A PC PaiN Classifieds Archive (3 months old+) 0 05-29-2011 04:45 PM
Dynojet Power Vision - and adjustable pushrods CHAINSAW Fuel Moto 0 03-14-2011 05:19 PM
