Pushrod adjustment - Road Glide Forums
 2Likes
post #1 of 26 (permalink) Old 03-20-2016, 12:31 PM Thread Starter
BigNorm's Avatar
Pushrod adjustment
First off I have to say my new build runs awesome 103, stock pistons, Veetwin performance street port,10:1 compression, Crane Cams chevy lifters, SE non tapered pushrods. I adjusted my pushrods 3 turns down and the valvetrain noise is obnoxious! The motor runs smooth as silk other than the noise. The power with this setup is really cool! I'm not sure if I'm bottoming out the lifter and need to loosen it up or try tightening them a flat at a time. Any help is appreciated. Thanks.
BigNorm is offline
post #2 of 26 (permalink) Old 03-20-2016, 12:51 PM
Road dawg's Avatar
Well I can tell you this on my 2011 fltrx with a 96 inch motor I did cams , same rods non-tapered as you did and S&S premium lifters and had noise, the HD paperwork said 2.5 turns I think, but when I call S&S they recomm 3.5 turns did that and the noise was gone, seems like these lifters needed more adjustment, but that solved my problem, hope this helps.
Road dawg is offline
post #3 of 26 (permalink) Old 03-20-2016, 01:04 PM Thread Starter
BigNorm's Avatar
It does help. It also helps to know you have S&S premiums because that seems to be as good as you can get yet you still had a similar issue. I guess I'll crank it down another half turn.
BigNorm is offline
post #4 of 26 (permalink) Old 03-20-2016, 01:09 PM
Road dawg's Avatar
Okay good let me know how it turns out, and good luck.
post #5 of 26 (permalink) Old 03-20-2016, 01:32 PM
turbochrisb's Avatar
Subscribed
turbochrisb is offline
post #6 of 26 (permalink) Old 03-20-2016, 02:32 PM
sj01fltri's Avatar
I have the SE push rods and i set mine at 3 turns running Fueling lifters and 574 lift cams,this motor is super quite.
sj01fltri is offline
post #7 of 26 (permalink) Old 03-20-2016, 08:22 PM
FrankieB's Avatar
First you need to figure out what the TPI of your PR's are, they are generally 24 or 32 TPI. I set mine .140 in the whole from zero lash. the math formula is..... number of flats=how deep you set them/[1"/(tpi*6)]... in my case #of flates=.140/(tpi*6)
midwaywfo and Ratdog33 like this.
06 RK
11 RGU
FrankieB is offline
post #8 of 26 (permalink) Old 03-20-2016, 08:59 PM
tdkkart's Avatar
You didn't mention what cams you're running, but some of them can be very noisy simply because of their fast ramp geometry.
What cams are they??
Somethings else, and I see you got this answer another forum, take a look at this.
Rockouts home
While not a total fix to the twin cam clatter, myself and a local friend have installed these in our 110s and they do work
to eliminate a large portion of the noise that many of use experience in the 2500-3500rpm range.
tdkkart is offline
post #9 of 26 (permalink) Old 03-20-2016, 09:21 PM
when doing my build I took into consideration that Harley doesn't include adjustable push rods in any of their kits, I'm assuming that this is because they can leave you stranded at the side of the road a 1000 miles from home and they don't want to be responsible, as for the lifters I also am running HD lifters..if I'm down and get hauled into a dealer I want them just to be able to walk into there parts stock and pick stuff off the shelf to get me mobile again...just a thought....had a Sportster that I ran all aftermarket and when it was down they didn't have supplies on hand........this is just for your consideration.
cheers
exracer2002 is offline
post #10 of 26 (permalink) Old 03-20-2016, 09:35 PM
tdkkart's Avatar
Originally Posted by exracer2002 View Post
when doing my build I took into consideration that Harley doesn't include adjustable push rods in any of their kits, I'm assuming that this is because they can leave you stranded at the side of the road a 1000 miles from home and they don't want to be responsible, as for the lifters I also am running HD lifters..if I'm down and get hauled into a dealer I want them just to be able to walk into there parts stock and pick stuff off the shelf to get me mobile again...just a thought....had a Sportster that I ran all aftermarket and when it was down they didn't have supplies on hand........this is just for your consideration.cheers
You can walk into a Chevy dealer or auto parts store anywhere in the country and buy lifters for a Harley twin cam motor.
tdkkart is offline
Adjustable Aluminum pushrod top ball broke off Sealdoggy Engine Related 6 02-08-2013 06:49 AM
Brand new SE 204 cam & adjustable pushrod kit Colin1966 Sold 1 01-08-2013 07:11 PM
pushrod ajustment help bigmatt1967 Engine Related 4 09-26-2012 06:46 AM
Step by step Cam removal/installtion and pushrod adj. Gonekat Do-IT-Yourself 5 12-06-2011 08:30 AM
Black Pushrod Tube covers/ NEW HD saddlebag extensions Peterod45 Classifieds Archive (3 months old+) 4 05-25-2011 03:49 PM
