Possible clutch issue. - Road Glide Forums
  • 1 Post By Road dawg
post #1 of 2 (permalink) Old 03-20-2016, 06:11 PM Thread Starter
Chromedclassic's Avatar
408 miles on my new RG. Pulled it into the garage the other night and stared backing it up. Felt like it was trying to go forward so I put it in N and finished backing it up. Went out about 1 hr later to plug in the battery tender and had fluid underneath. No issues with the bakes so I'm assuming its hydraulic fluid from the clutch line. Anyone else had any issues. The dealership came and picked it up yesterday am. Waiting on a diagnosis.
Chromedclassic is offline
post #2 of 2 (permalink) Old 03-20-2016, 07:24 PM
Road dawg's Avatar
Well I can tell you if your trans fluid is low it will def cause a hard shift or for it to be stuck in gear, I highly doubt you have a clutch issue at 408k, and with fluid on the ground im guessing a leak was the culprit, good luck.
Chromedclassic likes this.
Road dawg is offline
Cam Install possible issue Nightrain04 Engine Related 12 07-07-2014 09:23 AM
Electrical possible sensor issue...??? Johnzz1420 *General Road Glide Discussions/Pictures 5 08-05-2013 05:31 PM
Apparently, this isn't my week. Possible clutch issue RGCBandit Troubleshooting for Road Glides 3 10-15-2012 09:53 AM
stock 103 possible smoked clutch/slipping trans OuchMMC Engine Related 23 10-13-2012 10:29 PM
Clutch issue... ZachB Troubleshooting for Road Glides 21 04-19-2012 08:33 PM
