3 Hole Oil Change - Road Glide Forums
  • 1 Post By ironmark
post #1 of 5 (permalink) Old 03-25-2016, 04:56 AM Thread Starter
3 Hole Oil Change
Hey guys. Today iv gotta do a service on a buddies 2007 Street Glide. He's already scooped up the synthetic oil and filter. Could someone with the similar year please share with me how many Oz HD calls for trans, primary, and motor oil. Greatly appreciated.
(His birthday present may just have to be a service manual)
Joe.stevens101 is offline
post #2 of 5 (permalink) Old 03-25-2016, 08:07 AM
Smarty's Avatar
Should be 28 oz in the tranny, a full quart in the primary, put 3 quarts in the engine, crank it up to circulate, then check. If it is 1/2 qt. low, it's perfect. Don't put to the full mark.
2016 RGS Black Quartz
Smarty is offline
post #3 of 5 (permalink) Old 03-25-2016, 10:05 AM
Pretty sure 28 oz for tranny is if it's dry. 20-22 oz wet as you can't completely drain the gear box.
rg113 is offline
post #4 of 5 (permalink) Old 03-25-2016, 11:24 AM
32 oz (1 quart) in the transmission, I use 75 w140 full synthetic gear lube.
38 oz in the primary if you just do a oil change, if the outer primary cover is removed then you need to put 45 oz in the primary.
HD calls for 4 qts in the crankcase but from past experience 4 qts is too much oil, use 3 1/2 qts in the crankcase and everything is all good.
RGKen likes this.
post #5 of 5 (permalink) Old 03-25-2016, 03:11 PM Thread Starter
Thanks guys. Very much appreciated
To change or not to change them, that is the question Steelerdude1 *General Road Glide Discussions/Pictures 2 07-18-2016 06:41 PM
Lifters: to change or not to change BigNorm Engine Related 14 01-19-2016 08:50 AM
What to do with oil change oil? TearlessTom *General Road Glide Discussions/Pictures 15 11-22-2011 09:16 PM
Bottom slot hole on '11 RGU Stock Seat Lu Road Glide Specific Discussions 17 04-13-2011 10:36 PM
Enlarge internal wiring hole gja Controls & Handlebars 7 11-21-2010 09:18 AM
